| Home > Help Needed / General Tech Chat > Plugs for NA engine running MJ | |||||||
31st Aug, 2008 at 09:03:20pm
I've been having a bit of a problem with the plugs in the BOC, it's still running the MG Metty engine that I put in as a stop gap three years back, only mods being a stage 1 kit and MegaJolt.
31st Aug, 2008 at 09:05:31pm
Yeah resistive plugs are supposed to be used, although it didn't seem to make any difference on mine! lol Edited by matty on 31st Aug, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
31st Aug, 2008 at 09:13:21pm
is use standard plugs ngk's with no problems Edited by philc on 31st Aug, 2008. |
31st Aug, 2008 at 09:18:35pm
31st Aug, 2008 at 10:29:40pm
what he said Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
2nd Sep, 2008 at 10:36:55pm
Cheers guys that's exactly what I thought, now I need to figure out why two BPR6ES plugs died simultaneously after about 18 months. As an aside it was plugs 2&4 that died, very strange. Isambard Kingdom Brunel said:
3rd Sep, 2008 at 08:07:54am
I've got BCR8ES plugs in mine.
Edited by theoneeyedlizard on 3rd Sep, 2008. In the 13's at last!.. Just |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
9th Sep, 2008 at 09:45:39am
I may be being dim, but isn't the resistive 'R' more to do with radio interference than a performance thing ?
Metric is for people who can't do fractions. |
9th Sep, 2008 at 03:12:28pm
OEL if they are so sensitive to a bit of oil they are too hard (cold)for the job-try a grade lower.In my experience NGK,s dont take well to being cleaned,so once they are fouled its new ones every time. |
9th Sep, 2008 at 03:23:33pm
Are BCR7ES a grade higher?
Edited by theoneeyedlizard on 9th Sep, 2008. In the 13's at last!.. Just |
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
9th Sep, 2008 at 05:11:02pm
On 9th Sep, 2008 theoneeyedlizard said:
Are BCR7ES a grade higher? With the NGK's the higher the number the colder the plug. ie 8= cold and 6=hot. Champion plugs on the other hand are the other way around ie 9=hot and 6=cold. If the BCR8ES's are fouling try the BCR7ES's. Hope that helps "So wat we gonna do tonight Brain?"
