Home > Help Needed / General Tech Chat > edis modules and megajolt
ashley_dude00
Member #: 1751
chichester/bognor
did a search but can only find people selling stuff not with picture s and locations.also would a p reg fiesta have it on as my apprentice has decided he is going to scrap it and said i can have anythin on it.
what do i need off of a ford fiesta
the coil pack which i know.
what else pictures and locations onthe car would be greatly appreciated.
On 30th Aug, 2008 Richie said:
too much my wife says "not that friggin site again" so i pull my pants back up and turn it over to TM. *wink* iam on pretty much every day as i lead a sad existance
It looks like this...
Fiesta, it's usually on the bulkhead above the back of the engine
ashley_dude00
Member #: 1751
chichester/bognor
that and the coild pack and wiring with it is alli need.?? cheers for the picture will begoing to relieve his car of it this weekend .
colas
Member #: 102
Pennsylvania USA
You need the crank sensor too.
Any help:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5741
chace the harnes & snip the wires well back, especiall on the crank sensor sheilded wire
as bats pic shows, its the edis 4 unit without the vacume take off is the one you want.
Edited by BENROSS on 4th Sep, 2008.
shane
Member #: 1246
Lowestoft, Suffolk.
If you spend an hour un picking the wiring loom all the way back to where it enters the car (on the pasengers side of the engine bay) you should have enough cable to wire the whole megajolt in, coil pack edis, and sensor. If you do this you will have enough sheilded wire for the crank sensor to run along the front slam panel, up the inner wing accross the bulkhead, thru, and to under the dash where a few few of us have mounted the ecu, without joins or purchasing cable. Was a tedius job but Im glad I did it.
Shane
ashley_dude00
Member #: 1751
chichester/bognor
p reg should be about right.well im hoping so.then gonna order up megajolt
