| Home > Help Needed / General Tech Chat > 11 stud head fixing - thread size issue! | |||||||
![]() 36 Posts Member #: 2745 Member Milton Keynes |
6th Sep, 2008 at 04:30:12pm
6th Sep, 2008 at 04:44:05pm
Yes you can get smaller diameter studs.
Edited by Tom Fenton on 6th Sep, 2008.
6th Sep, 2008 at 04:58:37pm
sounds like perfectly normal engineering but he should have told you about the smaller stud required |
6th Sep, 2008 at 05:21:52pm
cheers for the speedy response.
![]() 465 Posts Member #: 1972 Senior Member Worcester |
6th Sep, 2008 at 08:52:42pm
Its what the standard cooper S had Chris cos they used 10 studs and a bolt in the thermostat side 11th stud, got some kicking about if you need one if you havnt bought ARPs m8,
6th Sep, 2008 at 09:44:44pm
cool Oli - i'll be in touch. just got a concern with oil pump mounting area to sort... |
1391 Posts Member #: 1686 Post Whore Oxford |
6th Sep, 2008 at 09:56:35pm
normall thing for the drillings to break through into the water jacket when going to 11 studs.
OMG Robert that's a big one |
6th Sep, 2008 at 10:28:44pm
7th Sep, 2008 at 02:02:21am
remember the bolt in the water pump end is only torqued to 20lb/ft not 50, like the rest of them "Turbo's make torque, and torque makes fun"
