Home > Show Us Yours! > Trackday experience - Bodyroll help?
lockfast
Member #: 2775
Aberdeen
Here are some pics of my min at my most recent trackday. First one since fitting my supercharger. Any thoughts on how to lose some of my bodyroll?
www.flickr.com/photos/johnsidc/2836146776/in/set-
72157607159962103/
www.flickr.com/photos/johnsidc/2835297305/in/set-
72157607159962103/
www.flickr.com/photos/johnsidc/2835296357/in/set-72157607159962103/
lockfast
Member #: 2775
Aberdeen
Hmmm I think you have to copy and paste thelinks to get them to open........sorry
antman
Member #: 358
Snetterton, Norfolk
KAD sell some anti roll bars, i haven't used them but have a set planned for the next build of mine.
Scruffy
Member #: 328
Seaford Rise, South Australia
I think you need to tell us what the spec of the suspension is - looks very soft
On 5th Sep, 2011 Vegard said:
lockfast
Member #: 2775
Aberdeen
I have standard rubbers all round with GMax shox. solid mounted front subframe and poly rear. Adjustable camber radius arms. Tie bars etc are all adjustable with poly bushes. I was going to put some red dot rubbers on but after reading various posts decided not to becuase of the increase in ride height with the rubber being so stiff. Tyres are Yokohama A539's
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
decent tyres and decent cones are the answer :)
AlexF
Here you go,
I found that the Red dot cones arn't that hard, in fact i'd almost say supple, although with 7x13's i guess the suspension has more leaverage against them.
Oh also, I will send your rods back! they slipped my mind. sorry!
Blimey have they got cop cars on track days now? They'll be sticking Gatsos up next! *surprised*
lmao came out the cinema the other week and we had been invaded by chavs and a couple of cops one in an evo(nice8-)) and one in a scooby and it was them too drag racing up the car park*surprised* they soon calmed down when i fired up the supra*happy* apparently its a regular thing*tongue*
lockfast
Member #: 2775
Aberdeen
Alex what tyres do you recommend? Mini13 Thanks for putting the pics up for me. And no panic with the rods! Been keeping an eye on your project so I know you are busy!
Bat the cop car as you put it is actually a race car that has been sponsored by some healthcare company or other so that would make an ambulance. I had a little nosey round it and think it would certainly get toa hospital in a hurry!
Brings a whole new meaning to the phrase ambulance chaser!
PaulH
Member #: 2340
Dublin Ireland
an AR on the back would make a huge difference but I would also say those shocks arnt worth a monkeys get you self a set of AVO the difference is amazing what sort of ride hight are you running have you a pic of it on the straight if you have a limo run an AR on the front as well and you will have a very nice difference
On 17th Feb, 2009 Rob H said:
get rid of the passenger!
jees you could lean out kiss the floor there mate.
What ever shocks you have won't really affect the ultimate body roll. yes they will affect the rate of change of body roll, but the car will roll as much as the 'spring' will let it.
So to improve matters you need stiffer springs or an ARB.
Red dots are the way to go IMO. As you've said, you know you'll need hi-los.
lockfast
Member #: 2775
Aberdeen
http://www.flickr.com/photos/johnsidc/2835...57607159962103/
Should be a pic of it on the sraight. I cant remember the exaxct ride height it is as low as I could get it without rubbing. Paul what is a limo (I presume you dont mean the stretched variety) The back and front arches have both been cut away to let it down and I alread have hi lo's Any recommendations of ARB's Cheers guys
The problem stems from the way the mini suspension works. As you lower it the spring rate reduces.
So if you are as low as you say you effectively have softer suspension than standard. The red dots will go someway to compensate, I ended up with yellows on the front plus front and rear ARBs.
I have the MS ARBs but these are not any use for a road car. They are hard enough to maintain when I only travel a few moiles per event.
Limo = LSD = Limited Slip Diff (won't help the roll)
PaulH
Member #: 2340
Dublin Ireland
Limo = LSD = Limited Slip Diff (won't help the roll)[/quote]
The reason I ask have you got a Limo is because when you fit a Front AR it has the tendancy to remove nearly all the presure from the wheel on the high side of the roll if you have a STD or Cross pin diff you will find that you will spinn the front wheel on the high side and lose drive, no a pleasant experence.
Sorry, I totally understood why you mentioned it, was just clarifing what direct influance it has on roll.
