Home > Help Needed / General Tech Chat > Car nolonger turns in after fitting coil springs
Mr Joshua
Member #: 1954
Luton Bedfordshire
Purchased a set of coil springs ( the hardest set supposedly for racing ) and fitted them. Now I find my car suffers from chronic under steer, squats excessivley under acceleration and in gentle corners.
Are there different makes that run different rates of spring? I assumed they were about the same, was I incorrect in this?
I was thinking about getting the rear springs swapped for another pair of front springs to see if this solved the problem, am I waisting my time and better of re-fitting my rubber cones and filing this under dont go there again?
Has anyone else had issues with these springs? If so how did you resolve them?
Own the day
far too stiff on the front now obviously,
carl
AllanMcD
Member #: 414
Dalbeattie Scotland
Is the car a bit high on the front? I had the same problem untill I lowered the front but I had to cut the high/lows.
Allan
http://www.rabdunn.co.uk/
Scruffy
Member #: 328
Seaford Rise, South Australia
Spring poundage was what exactly?
On 5th Sep, 2011 Vegard said:
Mr Joshua
Member #: 1954
Luton Bedfordshire
Good question, no idea. But on cornering you can visibly see the role of the body to the point where it seems that the inside wheel is lifting.
This is a major departure from how the car handled before and she is slamed at the front just about touching the bump stops the same height as with the rubber cones. the straight line ride comfort is much better but the cornering ability as taken a turn for the worse.
Any other thoughts
Own the day
I've read on here when you lower it a lot the top arm doesn't have the correct leverage against the spring, so effectively reduces the spring rate making it too soft.
Don't know if this applies to you?
What type of rubber cones did you have?
Is the rear higher than the front?
It sound as though the coils are softer as comfort has improved.
Edited by Bat on 13th Sep, 2008.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Standard cones were fitted to begin with. On fitting the coil springs I lowered the rear by one turn on the Hi-lo's.
Going to remove the coil springs and send them back ill live with the organ jarring ride so I can enjoy better handling.
Thanks for the comments.
Own the day
Are these are the springs that replace the cones, or the damper/spring units?
Minis were never designed with coil springs in mind *oh well*
Im sticking with my rubbers *tongue*
AllanMcD
Member #: 414
Dalbeattie Scotland
They wern't designed for Turbos, wide wheels, 200bhp, boy racers, racing, 16 valves, or even furry dice lol.
Allan
i have no experiance in setting up suspension other than my own but i would have thought that mixing rubber spings with coils springs is a no no, also putting a high poundage front spring compaired to the back on a fwd car is again something you just dont do
AllanMcD
Member #: 414
Dalbeattie Scotland
You can mix no problem you just need the right rate of spring.
Allan
Mr Joshua
Member #: 1954
Luton Bedfordshire
Ok. Gave it one last try jacked the rear up by 2 turns and the fronts up by a turn and a half.
Better but still not close to how she was. Talked to the retailer and was told that if there was any damage to the powder coating that he would not accept them back. Not even going to go there, what are the chances that they are blemish free.
I fear I have yet more expensive paper weights to find a home for,
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
Ahmen!
Own the day
AllanMcD
Member #: 414
Dalbeattie Scotland
If its understeering lowering the front or raising the rear helps try lowering the front to where it was with the rear as is.
Allan
Allan
Aww shit! I wish someone had told me about the furry dice :(
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
Minitastic springs???
Mr Joshua
Member #: 1954
Luton Bedfordshire
Allan
Did that and the stance was all wrong. The front wheels were right up in the arches with a 2" gap at the rear, not a good look. Ill let it settle for a while seeing as I doubt they will be going back and see if I can mess around with the settings and keep the stance.
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
Who?
Own the day
shouldnt really need to let them settle i wouldnt have thought. springs shoulnt really "seat down" like the cones do.
where you set them should be where they stay.
Mr Joshua
Member #: 1954
Luton Bedfordshire
No not from them.
Own the day
