Home > Help Needed / General Tech Chat > Wiring in new dash swicthes
jonb_5
Member #: 3193
Torbay, Devon
I have fitted new toggle switches to my dash for flashers, rear heater, fog light and headlights but the switches only have 2 spade connectors coming out of the back.
How do i connect these to the original wiring as the original indicator has more than 2 wires and so do most of the others.
It has been suggested that i use a relay, anyone know which one i need to use and how it wires up?
Thanks
Jon
It sounds to me as though you haven't got much idea about electrics, in which case I'd get someone who does to do the job.
Remember you set your car on fire at your own risk *wink*
Ben H
Member #: 184
Melton Mowbray, Pie Country
You need to look at the wiring diagram in the manual for your car. The light switch has more wires because it puts on the side and the main, so it has two positions and two switches inside. the hazzard switch is something else that I am not going to get into. The fog light is simple enough, ON or OFF.
http://www.twin-turbo.co.uk
