Make and Model: Mini City E
Year: 1989
Price: 2500 ono
Colour: Blue - Henley Blue (JPD - BLVC622)
MOT Expiry: May 09
Tax expiry: Apr/May 09
Mileage: < 1000 miles (Engine)
Manual or Automatic: Manual
Description
Purchased this little car back in late 2006 as a daily drive off retroracer1380 after he had just done a semi resto on it replacing a few panels and generally tidying it up.
Then in early 2007 I went and treated it to a 1330 replacement engine (see topic http://www.theminiforum.co.uk/forums/index...=40269&st=0 for full build and pictures) since then really the cars been off the road undergoing upgrades and tweaks only getting back just in time for L2B 08 which it did flawlessly for its first drive on a new re-built engine.
Its completely stripped atm with harnesses but wouldn't take a lot to just put some rear seats in and some carpet, heater is still present as i am not that hardcore.
The car itself doesn’t get used that much and has only really done Beaulieu Cooper Day and general trips around the area incl 2 Ace Cafe evenings when its sunny (I try not to let it see rainy days and its stays under its cover)
i have really done to many mods on this car to list them all but will list the main ones but please see links below for full mod lists
• MegaJolt Ignition System
• X-Pin Diff
• Cooper-S Brake Conversion
• Mocal Oil Cooler
• Safety Devices 6 Point Roll Cage
• Maniflow LCB & Miglia Style Exhaust Straight through Cone System
• 10x6 Gloss Black Wellers (incl 2 x spare)
• Snap-Off Boss Kit
http://www.theminiforum.co.uk/forums/index...tem&CID=121
http://img521.imageshack.us/my.php?image=82300899tn6.jpg
Overall this car needs a RR but drives effortlessly on the MejaJolt Map loaded. Has some rust under the driver’s scuttle/A panel (the normal place) but not much else where and generally is a solid clean shell and i will miss it lots
Also comes with car cover,retro roof-rack as used in the rallys, 2x 10x6 wellers as spares and nots of other spares incl clocks etc
The engine pulls very well and is a pleasure to drive even if its just around town or you want to have that power to overtake something. Its just a very smooth engine that delivers when you want or is happy to sit in traffic.
Spec Below
Block
• Block bored +60 thou at Morspeed.
• Block re honed to fit new piston rings. Bores ovality checked.
• All faces resurfaced.
• Chemically cleaned in hot acid dip.
• New corplugs added.
• High capacity oil pump.
• Worn Cam Bearing removed by Simon @ Morspeed and new one added.
• Painted in P.O red (heard this adds 25 bhp)
• Pistons are Hepolite 21251 +.60's with new piston rings from Minispares.
• 10.5:1 compression ratio.
• New Big End and Mains bearing shells. Crank journals and thrust washers measured.
• New crank oil seal added.
• New cam followers.
• Morspeed Phase 3
• New Duplex timing gears.
• Turbo Clutch and Flywheel
• New minispares gasket set and seals.
Head
• 12G940 Casting from SPi with water bypass hose.
• Modified by DTR Motorsport to stage 3 spec.
• Bronze valve guides.
• Head checked by Simion at Morspeed and larger inlet valves added to cope with increased displacement.
• 240lb Double valve springs to cope with increased lift of cam.
• Alloy inlet manifold.
• HIF44 carb with K&N filter.
• Payen BK450 head gasket set
Gearbox
• Rebuilt by Guessworks
• Central Oil Pick up pipe fitted.
• Comp x-pin diff fitted.
• Gear linkage seal kit used to prevent any leaks.
• S/C drops 1:1 ratio
Exhaust
• Maniflow LCB with straight through cone centre miglia style exhaust (de-cat)
Pictures below
http://img528.imageshack.us/my.php?image=h...ooksnow1fu0.jpg
http://img212.imageshack.us/my.php?image=h...ooksnow2wo0.jpg
http://img219.imageshack.us/my.php?image=imgp2762va4.jpg
http://img440.imageshack.us/my.php?image=imgp2372kn9.jpg
IF YOU HAVE ANY QUESTIONS TO ARRANGE A VIEWING/DRIVE PLEASE PM ME
There is nothing wrong with this car and am selling due to personal reasons
Taz
Edited by t@z on 23rd Sep, 2008.
www.twitter.com/lilpinkiy
