| Home > Help Needed / General Tech Chat > Weber 45 aux chokes | |||||||
25th Sep, 2008 at 08:51:24am
does anyone know the right way these fit into the barrel, i have forgotten how they cam out. Thanks |
559 Posts Member #: 2775 Post Whore Aberdeen |
25th Sep, 2008 at 08:57:35am
They should have little dimples in them for the brass grub screw that holds them in place that should give you a fair indication. But generally the wide parts go to the filter side tapering to the manifold side. |
25th Sep, 2008 at 09:18:59am
got the dimple thing, so i am clear, the choke with the small tube in the centre, the wider part of this small tube should be facing me? |
1050 Posts Member #: 764 Post Whore Staffordshire |
25th Sep, 2008 at 11:12:11am
IIRC they will only go in one way? i.e. teh dimples are slightly offset to the centre to stop you doing it wrong? |
25th Sep, 2008 at 11:15:01am
got it now thanks guys |
25th Sep, 2008 at 06:25:25pm
just wanted to make sure before i put i back on. is this the right way
25th Sep, 2008 at 08:12:21pm
25th Sep, 2008 at 09:16:21pm
thanks running again, |
25th Sep, 2008 at 09:20:42pm
good stuff, what engine spec is it? "Turbo's make torque, and torque makes fun"
25th Sep, 2008 at 10:44:41pm
any better? |
26th Sep, 2008 at 07:34:46pm
On 25th Sep, 2008 Anton said:
any better? will need re jetting again, been to see john today, suggested to get the tps up and running, change the exhuast, and maybe put those ram pipes in. He did say don't bother changing the exhaust and inlet manifold just yet, he did not feel it would benefit. so i will see how it goes. try the cheap options first |
