| Home > Help Needed / General Tech Chat > problem with mixture(i think) | |||||||
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
4th Oct, 2008 at 02:30:50pm
I have a problem with the tune of my car i seem to have a miss fire on cruse at between 3500 and 4000 rpm right where i need to be to cruse at between 60 and 70mph what the problem is is that at this speed and rpm the turbo is spooling up this is causing problems to get the mixture correct. Everywhere else the mixture is perfect and the car runs a dream but try sitting at between 60 and 70 on the motorway and it will pop and miss "Tuning should be a compromise between what is possible and what is necessary"
69 Posts Member #: 1670 Advanced Member |
4th Oct, 2008 at 02:51:39pm
what do you mean by t3 cam |
4th Oct, 2008 at 03:09:39pm
I think he means a morspeed t3 cam?
On 4th Oct, 2008 spacecowboy said:
what do you mean by t3 cam 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
4th Oct, 2008 at 04:03:18pm
4th Oct, 2008 at 05:10:47pm
It'e be the MED T3 if he has the MED bottom end, that's basically an Avonbar PH2. On 7th Nov, 2008 Nic said:
4th Oct, 2008 at 05:14:54pm
Def not icing (id say) I had it in a temperature controlled dino and it still did it at the given rev and speed it is only when it is on part or light throttle.
Edited by turbominij on 4th Oct, 2008. "Tuning should be a compromise between what is possible and what is necessary"
4th Oct, 2008 at 07:06:57pm
have you the part lean off pipe connected up? if so you could try cutting it in half and blocking each end up see if it improves. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
4th Oct, 2008 at 07:16:13pm
On 4th Oct, 2008 chinlesswonder said:
have you the part lean off pipe connected up? if so you could try cutting it in half and blocking each end up see if it improves. I agree. On anything other than a stock motor the lean out pipe can upset the mixture quite a lot. |
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
4th Oct, 2008 at 11:29:31pm
Do you guys have any trick setups for this, any with ease fitment of the auld "t" piece. (chopin the lean off pipe, which i take is the carb to manifold loopy bit of pipe) |
4th Oct, 2008 at 11:54:32pm
before you block them off mate and possible disrupt the needle/set-up, as if it still has the lean-off pipe on it will have been set-up to incorporate this, put a new peice of pipe on. There only has to be slight pin pricks in this pipe and it will send you chasing things.
5th Oct, 2008 at 12:29:58am
5th Oct, 2008 at 11:06:45am
1972-ANGUS = highjacker Edited by turbominij on 5th Oct, 2008. "Tuning should be a compromise between what is possible and what is necessary"
5th Oct, 2008 at 04:05:58pm
Yeah, thats a good idea and should work perfectly, you just have to remember to switch it if you want to accelerate on boost. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
