| Home > Help Needed / General Tech Chat > Uprated Actuator | |||||||
7th Oct, 2008 at 07:44:41pm
Got an Avonbar uprated actuator from the box of bits that came with the engine when I bought it.
7th Oct, 2008 at 08:32:38pm
why not run the standard actuator while running it in?
7th Oct, 2008 at 08:51:57pm
looks like the 10psi one i have from Avonbar. What do you mean by wind down the actuator, there is nothing to wind down, it depends on the preload on the wastegate. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
7th Oct, 2008 at 09:26:11pm
On 7th Oct, 2008 James_H said:
why not run the standard actuator while running it in? actually i just thought about that and it would be a PITA to change!!! I was thinking this, but would rather not because looking at the condition of my std actuator I think a suitably sized branch would have more of the desired effect haha. On 7th Oct, 2008 chinlesswonder said:
looks like the 10psi one i have from Avonbar. What do you mean by wind down the actuator, there is nothing to wind down, it depends on the preload on the wastegate. Im not entirely sure, I think I need to do abit more research but I assumed that as the actuator will go up to say 10psi without a bleed valve, it could be adjusted to run at a lower pressure while I run in? Or is it fixed at that pressure? I was under the impression that you could adjust the preload to change the boost at which the actuator opens? |
7th Oct, 2008 at 09:35:51pm
why not use your bleed valve and a boost gauge and set your car to the desired boost for the "run in" period? Drives
7th Oct, 2008 at 09:44:29pm
Because if I used a bleed valve the pressure would go up which I dont want it to? |
7th Oct, 2008 at 09:54:38pm
i thought you could adjust it up or down? Drives
7th Oct, 2008 at 09:58:50pm
taken from Avonbar
7th Oct, 2008 at 11:12:57pm
Assuming the turbo is out of the car on the work bench. Fit the actuator to the turbo with no preload, then connect up & foot pump and decent boost gauge to the actuator then slowly increase the simulated boost until the waste gate opens, read how much "boost" the gauge is showing. Vola. Isambard Kingdom Brunel said:
8th Oct, 2008 at 10:45:53am
On 7th Oct, 2008 Rob H said:
Assuming the turbo is out of the car on the work bench. Fit the actuator to the turbo with no preload, then connect up & foot pump and decent boost gauge to the actuator then slowly increase the simulated boost until the waste gate opens, read how much "boost" the gauge is showing. Vola. I will try this tonight!! Correct me if im wrong, if I set the preload so the actuator operates and opens the wastegate at 10psi, if the bleed valve is fully closed it should still boost to 10psi anyway correct? I was thinking, I might just adjust the actuator so that the pre load is set to 10 psi (which I want to be my low boost setting) and just not rag it while im running it in lol. Then when I go to get it set up the tuner can just set the car up for 10psi and use the bleed valve to raise it and set it up on 15psi+? This will save me having to bleed off boost to achieve 10psi which surely must be a waste, and just bleed off the signal when I want to run the higher boost? |
8th Oct, 2008 at 11:39:01am
yeah, you use the actuator to set the minimum boost level, then you can use the bleed valve for increasing it above that "Turbo's make torque, and torque makes fun"
8th Oct, 2008 at 08:29:29pm
this is the same one as i have
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
8th Oct, 2008 at 09:08:51pm
Preload makes all the difference. If you want to see what the actuator is rated at, hook it up to a bike pump with a gauge on it, that's what I did... |
8th Oct, 2008 at 11:45:40pm
Hmm tried the bike pump method but the fixing didnt fit over the take off on the actuator!!
9th Oct, 2008 at 07:51:24am
9th Oct, 2008 at 08:06:07am
What would that create, boost creep?
9th Oct, 2008 at 08:39:50am
Anyone know offhand what a T31 is rated at - or does it depend where it came from ?. |
9th Oct, 2008 at 01:25:39pm
You can change the preload when it's on the car. That's what I did.
9th Oct, 2008 at 01:30:58pm
Ric how hard was it to adjust the preload in situ?
Edited by richminiturbo. on 9th Oct, 2008. |
9th Oct, 2008 at 01:33:36pm
i've changed the actuator easily enough in situ with a 1/4"drive socket set.
9th Oct, 2008 at 01:48:26pm
Haha good point!!
9th Oct, 2008 at 01:58:29pm
to be honest, i normally only do about half a hole width.
