| Home > Help Needed / General Tech Chat > cuts out when hot! | |||||||
11 Posts Member #: 2364 Member |
10th Oct, 2008 at 12:14:52am
Hi, My mini starts really well when cold but after it has warmed up it will occasionally stall at traffic lights and will struggle to start again :( ..... After it has cooled down it starts ok.
10th Oct, 2008 at 12:22:54am
what engine do you have in turbo? mpi? or spi or carb?
10th Oct, 2008 at 12:28:42pm
It has metro turbo lump with a carb. |
10th Oct, 2008 at 01:20:00pm
Fuel pressure or fuel evaperation, coil losing effiency when hot and/or spark plugs doing same. Own the day
10th Oct, 2008 at 01:40:30pm
Check your fuel pressure, this happend to me. Fuel evaporation usually occurs a little while after its been sat not straight away. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
10th Oct, 2008 at 03:07:35pm
also may be to lean at tick over always looking for them bigger bunches of bannanas |
10th Oct, 2008 at 05:44:03pm
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
10th Oct, 2008 at 06:14:05pm
Does it run really rough when it starts again? Mine was doing that, spark was fine, carb was fine, but my valve clearances were way too tight. Worth a look. |
10th Oct, 2008 at 06:45:54pm
as above
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
11th Oct, 2008 at 08:41:02pm
damn i was gonna say the heat shield too.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
11th Oct, 2008 at 08:43:53pm
coil? |
12th Oct, 2008 at 09:16:14am
Got a similar issue with my NA metro engine, after hard motorway driving and coming off a slip road it cuts out at the junction and is a bastard to start, i'm putting it down to evaporation. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
