| Home > Help Needed / General Tech Chat > Alternator Wiring | |||||||
10th Oct, 2008 at 05:22:00pm
Fellas, after wiring up my Alternator (Nippon Denso), my car seems to struggle a little when turning over. Also when i connect the batt i get a bit of a spark.
10th Oct, 2008 at 05:27:35pm
my battery on the 106 mini and most other cars sparks when i re-connect it depending on what side you took off Drives
10th Oct, 2008 at 05:30:30pm
10th Oct, 2008 at 05:32:09pm
But if you disconnect the alt plug it doesnt do this. Obviously if this is happening there is a draw of power somewhere.
On 10th Oct, 2008 Paul R said:
my battery on the 106 mini and most other cars sparks when i re-connect it depending on what side you took off 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
10th Oct, 2008 at 05:32:35pm
IIRC the positive goes to the switched live, looks like it is on permanantlyu there. On 28th Aug, 2011 Kean said:
10th Oct, 2008 at 05:34:10pm
The Green and Brown wire goes to the ign feed the lights feed then off to the solenoid.
10th Oct, 2008 at 05:38:17pm
Obviously my Lamp Feed and Main Power Lead are correct, its the ign thats to cock. Bat they are perm i think 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
10th Oct, 2008 at 05:38:36pm
10th Oct, 2008 at 05:39:52pm
If the ignition feed to the alt is permanent that'll be the problem, as the field winding will be permanently excited
10th Oct, 2008 at 05:43:09pm
OK ive got an excited the alternator, So is IGN Light and Main Wire ok?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
10th Oct, 2008 at 05:47:00pm
Edited by Bat on 10th Oct, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
10th Oct, 2008 at 05:49:32pm
So all i need to do is connect the IGN wire from the green connector to the ign feed where? Sorry im a spaz when it comes to wiring. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
10th Oct, 2008 at 06:31:59pm
11th Oct, 2008 at 10:59:14am
So run a wire from the IGN Live on ths alternator to one of the spades next to the grn wires on the fuse box. Does it have to be a decent gauge wire? Also, what exactly does this wire do? Edited by MikeRace on 11th Oct, 2008. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Oct, 2008 at 09:50:19pm
11th Oct, 2008 at 09:53:38pm
Right on, im probably thinking it may be a frigged Alternator then! It was from fleabay so ive probably been shafted. Following the 1275GT Wiring Diagram the the wire goes direct to the large spade on the solenoid? Could i not just do this? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Oct, 2008 at 09:56:39pm
11th Oct, 2008 at 10:00:44pm
Brown and Blue Signal Wire 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Oct, 2008 at 10:01:07pm
Im refering to this.
11th Oct, 2008 at 10:16:04pm
11th Oct, 2008 at 10:17:41pm
Right, ill run a wire to the fuse box, what about the existing loom wires, shall i just isolate these from eachother. (the ones that go to the control box) 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Oct, 2008 at 10:24:10pm
Yup :)
11th Oct, 2008 at 10:24:43pm
Cheers Mate! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Oct, 2008 at 10:26:58pm
11th Oct, 2008 at 10:29:51pm
Will be sorting this tomoz. Ill update tomorra aft!
