Home > Help Needed / General Tech Chat > What thread GT 15
PaulH
Member #: 2340
Dublin Ireland
Hay guys My self and Spanner are making up some oil lines for the GT 15 has anyone any idea what size and type thread the presure side input of the GT 15 is ??
On 17th Feb, 2009 Rob H said:
Turbo Tel
Member #: 588
Delaware, USA
search and you will find, but anyway here they are
http://www.turbominis.com/forums/index.php?p=vt&tid=138086
PaulH
Member #: 2340
Dublin Ireland
that linke no worke thanks Tel I did do a Serch but Im sure im just operating the search engine rong I need more practice,
thanks tel.
Turbo Tel
Member #: 588
Delaware, USA
link works fine here in the USA...
Just type "GT15" Its under "GT15 connections" can't be plainer than that?
for the searchbutton impared....
Not that there are many out there doing GT15s but I had a bugger of a time confirming this..so here goes.
Oil feed----7/16x24 inverted flare (like a 1/4" brake pipe fitting)
Drain------same as most of the GT series but different to T3
water------14mmx1.5
Terry
Edited by Turbo Tel on 17th Oct, 2008.
Turbominis.com doesn't work in the UK AFAIK?
Turbo Tel
Member #: 588
Delaware, USA
Luckily for you I'm really bored here , loading software on a workstation at a hospital for the 3rd time today...
Heres an example of the fitting, this one is unrestricted which they suggest is OK for the GT15, there is also another that has a restriction, said to be for the "bigger turbo's"
They refer to it as a 1/4" inverted flare but I think they just mean that its the same as 1/4" brake pipe inverted flare fitting, the thread is actually 7/16x24
http://www.atpturbo.com/Merchant2/merchant...y_Code=ATP-OIL2
PaulH
Member #: 2340
Dublin Ireland
Mister tell your a legend thanks a million I think me blody internet went down at the same time as I tryed you link Im not having a good day thanks again,
Enjoy you computing :)
