| Home > General Chat > Started First Time - With Problem (now running update) | |||||||
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
18th Oct, 2008 at 06:18:24pm
Some of you may have seen my limited build thread http://www.turbominis.co.uk/forums/index.php?p=vt&tid=9373
Edited by Dicanio on 26th Oct, 2008. |
18th Oct, 2008 at 06:22:30pm
5 bar sounds fine on a cold engine |
18th Oct, 2008 at 06:24:35pm
halfords ey.... haha
18th Oct, 2008 at 06:30:22pm
Yep new oil filter is in order, if i've trapped the rubber gasket it's a school boy error, but suppose something had to go wrong!!!
18th Oct, 2008 at 06:31:42pm
Thanks Iain, that puts my mind even more at rest, lets just hope it was a simple f**k up |
19th Oct, 2008 at 02:56:02pm
Well, looks like it wasn't an error in the fitemnt of the oil filter, replaced it today, started her up, ran for a few seconds, then pop. It blew the oil filter clean off.
Edited by Dicanio on 19th Oct, 2008. |
19th Oct, 2008 at 03:10:52pm
5 BAR is approx 75 psi, which is more than i'd exect at idle,
19th Oct, 2008 at 04:00:58pm
Relief valve sound promising, it's got one of those adjustable things on, think I'll order new standard stuff and give it a go. Bloody oil everywhere at the moment, not to dis-heartened though, at least it starts!! |
19th Oct, 2008 at 04:11:33pm
or chop a couple of turns of the existing spring.
19th Oct, 2008 at 05:14:33pm
By 4mm, i'm assuming that with the cup and spring in the block and the nut offered up the there is 4mm to push the nut to engage the threads.
19th Oct, 2008 at 05:17:06pm
SOUND LIKE THATS THE ISSUE oops caps,
19th Oct, 2008 at 05:19:41pm
Hope so, feels like i'm very close to having a running car, which after a 6 year build is a bit of a motivator!!
19th Oct, 2008 at 05:29:05pm
I meant that it just sounds like the spring is too long,
19th Oct, 2008 at 05:36:55pm
Yeh, plan was just to replace it with standard at the moment and see whats what, though just read on MiniSpares website that the adjustable ones cannot affect idle oil pressure, which is a bit of a worry.
19th Oct, 2008 at 05:49:14pm
I'm sure I've got some standard relief v/v bits somewhere if you want to pop through sometime?
19th Oct, 2008 at 05:50:49pm
That would be cool Tom, could drop off that gearbox if you still want it. Do you think I'm on the right lines? |
20th Oct, 2008 at 09:56:46am
75 cold isnt too high, its at the top end but not excessive, but sounds like its going much higher than that |
20th Oct, 2008 at 12:30:51pm
Yeah 75psi is fine, mine is at least that from cold at idle. I would stick with the original spring and shuttle PRV setup rather than the ball and spring though. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
20th Oct, 2008 at 08:46:03pm
Looks like it runs at 75psi for a little while and then the pressure builds in the oil filter, second time it blew it clean off.
20th Oct, 2008 at 09:09:49pm
yes not too high exactly but at the top end.
20th Oct, 2008 at 09:33:13pm
10-15 seconds at most |
20th Oct, 2008 at 10:59:49pm
that really doesn't sound like the releif valve, more like a return blockage, especially for it to blow off the filter. Can you not try it with a new filter and without the sandwich plate and take the pressure reading from the oil switch takeoff? 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
21st Oct, 2008 at 09:41:08pm
Right, I've had another quick look at this tonight, only a quick look though as I was at work till late.
21st Oct, 2008 at 10:29:16pm
i might be wrong but im under the impression that the oil flow is in the opposite direction to what you are thinking.
22nd Oct, 2008 at 12:30:46am
James, a bit of research would suggest you are correct, and the fact that the lttle ball in the housing (don't know it's proper name) pushes up would back up your theory.
