| Home > Help Needed / General Tech Chat > fueling and oilways problems (fitting a std t3 setup) | |||||||
![]() 233 Posts Member #: 863 Senior Member Lathom, lancs |
25th Oct, 2008 at 01:09:26am
hi there,
25th Oct, 2008 at 02:37:18am
Just to add, anyone local to lathom, lancashire that wouldnt mind popping down for abit helping out for beer tokens it would be greatly apreciated Edited by MINIMON on 25th Oct, 2008. |
194 Posts Member #: 2873 Advanced Member Milton Keynes |
25th Oct, 2008 at 04:01:21am
2) My oil return from the turbo goes to the blank and works perfectly.
25th Oct, 2008 at 10:21:14am
25th Oct, 2008 at 12:58:34pm
thanks mate,
25th Oct, 2008 at 01:00:25pm
Thanks tweaked, with regards two it was that i was abit struck with.. i didnt no where they went on the block haha, i understand it abit better now thanks |
25th Oct, 2008 at 02:48:01pm
I dont like the sound of the pipework you propose to use as it is plastic of some sort which may or may not be long term proof against fuel.Most people use copper. |
25th Oct, 2008 at 03:13:12pm
If it's central heating "plastic" pipe you're thinking of, I agree entirely with tadge44... DON'T.
Edited by Rod S on 25th Oct, 2008. Schrödinger's cat - so which one am I ??? |
25th Oct, 2008 at 09:17:18pm
hmm, i will have to check it. i got it when i bought the kit off a mate so i may ask him what it was, it appears to be a plastic type construction, but i will ask to be on the safe side.
26th Oct, 2008 at 01:18:25am
the throttle cam is just on the other side of tha carb?
26th Oct, 2008 at 01:26:48am
there isent a fixing for it thats the problem, the mounting on the plate between the inlet and carb is there for it to be on the other side but there doesent appear to be a ''cam'' if thats what its called?
Edited by MINIMON on 26th Oct, 2008. |
60 Posts Member #: 4055 Advanced Member teeside |
26th Oct, 2008 at 06:20:23pm
alright mate had same problem with rev cable i went to local scrapyard and took one of another car i used one of them threaded bar types with the 2 nuts cable goes through middle dont know name of them but do you get my drift had to look for a while as most are bigger and wont fit in grooves |
26th Oct, 2008 at 06:36:59pm
only mocked up when i took this pic, obviously the sandwich plate to secure the cables is missing
Edited by joeybaby83 on 26th Oct, 2008. "Turbo's make torque, and torque makes fun"
27th Oct, 2008 at 12:33:39am
THATS GREAT! (yes caps needed haha) i could probbaly nock one of them up, i was under the impression they were suposed to have a small dish like all other accelerator cams have |
27th Oct, 2008 at 04:33:12am
Not necessary |
27th Oct, 2008 at 06:51:20pm
helpful... lol its on and seems to be fine with the return pipe (the turbo is loosely on)
28th Oct, 2008 at 11:59:21am
On 27th Oct, 2008 tadge44 said: depens on the type of bolt fitted! if the bolts have a shouilder then leave it on it does no harm, if ther is no shoulder and they are the screw type then you can leave it out.
Not necessary Why the hell dont you just fit the turbo carb as is? your standard carb is not sealed to take the intake pressures and you may find you have fuel leaaking from your spindle shaft. Why muck around swapping bits over! 1.What about the balance pipe that feeds posative pressure into the float chamber there is no fitting on the standard carb for this. 2. have you thought about swapping the needle and jet over. What about the dash pot spring. If it were that easy to just bolt any carb on Webber would be my first port of call. Own the day
29th Oct, 2008 at 07:38:07pm
thanks about the shoulder thing mate, its all fitted and sorted.
Edited by MINIMON on 29th Oct, 2008. |
29th Oct, 2008 at 09:15:15pm
OH-OH! ive just read elsewhere on the forumt hat a redtop fuel pump cant handle more that 3.5 psi, is this true?
29th Oct, 2008 at 11:00:50pm
29th Oct, 2008 at 11:06:55pm
its all going in a metro though... :lol: i cant fit a MPI tank Edited by MINIMON on 29th Oct, 2008. |
29th Oct, 2008 at 11:09:52pm
mon, have a search in the 'how to' and faq section, all these things have been answered a million times over "Turbo's make torque, and torque makes fun"
29th Oct, 2008 at 11:17:43pm
i cheers dude, i was just on that i was going to edit my post and u had already replied, i feel a n00b now lol thanks for that :p |
29th Oct, 2008 at 11:42:52pm
http://rallynuts.com/motorsport/FACET_Fuel...ump_Kit_384.asp
10mm I think?
im just going to either find a Turbo sender with return feed and a fuel pump off a turbo or try and use the facet red top i have
