Home > Wanted > The bolt and spacer from a verto clutch bracket
Just trying to fix a mates car, i need the bolt and spacer that goes into the wok on the bottom of the angled verto clutch mount.
Either that or the dimensions and thread so i can sort one. He cant get it into gear!!
i think its 1/4unf?
Star Mag
Member #: 375
Leicestershire
Yep it is 1/4 unf should be able to get one locally?
I can, but i dont know the length of the spacer piece?
Star Mag
Member #: 375
Leicestershire
Ah sorry see what you mean now! getting confused with the pre verto setup! *oh well*
Anton
Member #: 764
Staffordshire
i'm pretty sure its 1/4" UNC not UNF.. i had major troubles finding one.
no idea on the spacer length tho...
Edited by Anton on 27th Oct, 2008.
The spacer is about 26.5mm long (1, 1/16") but the replacement ones (I bought one from Moss) are way too thin.
So I machined one up from thick walled 1/4" bore tube.
Bolt is 1/4" UNF, it would be the clutch setting bolt on a pre-verto.
Yup, its 1/4" unf x 1 3/4" long
found it in the end on the minispares website where they handily told me thread and length!
Cheers for the tube length, i'll find something suitable or machine something. On the minispares website it says they use the centre from dog bone rubber steadies.
I got both off ebay for about £2 in stainless *wink* Postage wasn't robbery either :)
