| Home > Help Needed / General Tech Chat > Tacho going a bit mental when thins such as lights are swiched on | |||||||
3rd Nov, 2008 at 07:35:04pm
The mini after running very well for 3 years has decided to begin being a bit of a pain in the arse (also taking into account the oil pressure thread)
Edited by minimole23 on 20th Dec, 2008. On 7th Oct, 2010 5haneJ said:
3rd Nov, 2008 at 07:51:06pm
coil earth will be a good place to start.
3rd Nov, 2008 at 08:00:38pm
20th Dec, 2008 at 06:35:02pm
today I went through all the earths and also had a play with the fuse box and around the coil area.
20th Dec, 2008 at 06:44:47pm
i'd have gone with the above of earth straps or live feed to the coil but considering your comment below, could be HT leads? and sorry, couldnt veiw the vid, didnt work for me
On 3rd Nov, 2008 minimole23 said:
and you can feel the sparks getting fired out of sink, but corresponding to whichever position the tacho is in. Thanks James |
20th Dec, 2008 at 07:21:18pm
I've changed the ht leads, I will go and take the ignitions system apart and see where things go from there and report back.
20th Dec, 2008 at 08:18:04pm
My tacho goes crackers when I indicate to turn right.
20th Dec, 2008 at 08:35:57pm
On 20th Dec, 2008 Paul S said:
My tacho goes crackers when I indicate to turn right. I know what the problem is. The printed circuit board at the back of the instrument pod has been repaired but there is an earth leak. So the tacho signal gets earthed when the turn indicator in the pod operates. Might just be worth checking the connections at the back of the pod. I will try that, but you can definately feel the difference in the way the engine pulls, when the tacho dances, so I'm inclined to think it is responding to whatever the coil is doing. on which note I have also changed that in an attempt to cure the problem. On 7th Oct, 2010 5haneJ said:
21st Dec, 2008 at 12:34:32pm
I've had enough of this, now the starter motor has just died I think.
21st Dec, 2008 at 01:34:43pm
Have you checked that your battery is good and the alternator is putting out enough volts? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
21st Dec, 2008 at 03:06:44pm
Fixed it. I changed the ignition module as a last resort and it seemed to have worked. no problems now.
