| Home > Help Needed / General Tech Chat > Boost gauge plumbing and boost adjuster | |||||||
![]() 233 Posts Member #: 863 Senior Member Lathom, lancs |
8th Nov, 2008 at 08:21:03pm
Hi there,
8th Nov, 2008 at 09:09:32pm
Put the To Turbo bit to the Dizzy Feed feed on the carb and then remove the T-Piece from the Boost Adjuster setup completely. Then on the T-Piece (that has to boost gauge written on it) plumb your dizzy advance retard tube or you dump valve on here.
8th Nov, 2008 at 09:42:03pm
Thanks mate, with regards the dizzy then do i just put a T in the dizzy pipe are i still have to use it on the dizzy?
Edited by MINIMON on 8th Nov, 2008. |
8th Nov, 2008 at 10:18:19pm
well, ive redone some drawings :-? ok pikey rough paint diagrams, they should make sense. the first is what you said, but then where does the adjuster go and the gauge as there are no other places i can see on the carb or inlet for them to go?
9th Nov, 2008 at 12:42:33am
9th Nov, 2008 at 09:54:32am
or if you want it done today pop down your motor factors and buy a couple of brake calliper bleed nipples. drill and tap them into your inlet manifold and use one as the feed for your boost gauge and the other as a spare or for if you fit a dump valve.
9th Nov, 2008 at 12:46:11pm
Ohh, that makes sense thanks guys.
