| Home > Help Needed / General Tech Chat > Nippon alternators & water pump | |||||||
12th Nov, 2008 at 08:28:34am
Does anyone else have or had this problem. Where the alternator bolts to the water pump, this keep cracking. How can i remedy this and stop this from happening?? |
12th Nov, 2008 at 09:47:08am
Whats cracking, the alternator or pump?
12th Nov, 2008 at 10:00:54am
water pump, right through the hole that the bolt goes through to fix to the block |
12th Nov, 2008 at 10:49:48am
Hmm seems a little odd? Maybe something like this may help?
12th Nov, 2008 at 10:54:44am
use a long bolt and a sp[aces and use the alternator monting on the block to stabalize it.
12th Nov, 2008 at 11:35:36am
this is exactly what i need, that is showing a small bracket from the water pump to the alterator though. is that to line it up with the alternator bracket?? |
12th Nov, 2008 at 12:03:43pm
Its been mounted "upside down" compared to mine and others. The lug on the bottom of that pic is offset a little more so it will bolt onto the pump, and near enough line the pulleys up. Notice there is also spacers between the second mount and block to bring that inline too.
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
30th Nov, 2008 at 05:40:52pm
Only just seen this post!
30th Nov, 2008 at 07:09:16pm
i have given up with it for the time being, I have gone through 4 water pumps so have put a normal one back on, until i have time to do something like matty |
