Home > For Sale > 1330cc mayfair
tuktuk
Member #: 1675
Make and Model: mayfair
Year: 1989
Price: £2750ono
Colour: azure blue met
MOT Expiry: june 09 ? will have to check
Tax expiry: 6 months
Mileage: 55k
Manual or Automatic: manual
Class C/D write off? previous cat c
Description
interior
6 point rollcage with rear cross door bars and dash bar, painted luminous yellow
cobra monaco seats in black leatherette type material with white piping
silver/yellow sabelt 4 point harnesses
silver dash with radio housing and glovebox, 3 auxillery guages
custom chequerplate doorcards
6x9's under rear seat and 13cm components on rear shelf
rear seat carpeted
exterior
w&p arches
6x12 revos - black
debumpered front end
metal flipfront
carbon fibre bonnet
Clear jewel type rear lights
Chrome grill etc
Bullet door mirrors
engine
1330cc (1275cc +0.60) A+ Block
Kent 286MD cam
mg metro large valve head - decoked, valves relapped, new stem oil seals, BK450 head gasket and thermostat blanking sleeve
Polished crank, new thrusts and bearings when built
centre main strap
turbo oil pump
duplex timing chain
oil cooler and braided hoses
2 core super cool rad
HIFF44 carb, stage 2 LCB, alloy inlet manifold, K&N weber style air filter
straight through centre exit twin DTM exhaust system
Electronic Dizzy *no points *happy* * with silicon 8mm Red ignition leads, NGK plugs
A+ Gearbox, 3.44diff, new gear linkage and drive shaft seals
Chrome rocker cover, t-bars and cap
only done 3000 since build
Suspension / Running gear
Just had new front wheel bearings, discs and brake pads only afew weeks ago.
Fitted with gaz adjustable shockers all round and Hi-lo adjustable suspension
Larger type 306TD battery fitted for better cranking/radio/ice etc
project thread http://www.theminiforum.co.uk/forums/index...showtopic=69774
can be delivered anywhere in uk
thats all i think
