| Home > General Chat > Good starting point? | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
17th Nov, 2008 at 01:17:11pm
As you may have read in the wanted section I'm on the lookout for an engine or bits of engine to put one together after Morspeed totally let me down with a 1380 kit.
17th Nov, 2008 at 01:20:30pm
if its for a turbo I would not go for a 1400... Its scrap when the bores are worn... also I wouldnt touch Jon/jokespeed myself... |
17th Nov, 2008 at 01:45:53pm
yes a 74 mm bores would leave it quite thin in the bores, it would prob be ok if low com and low boost, but the biggest bore i would use for blowing would be 73.5 mm. Best 1/4 mile 13.2 seconds @116 mph
17th Nov, 2008 at 01:58:44pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=255158
17th Nov, 2008 at 02:28:51pm
On 17th Nov, 2008 richminiturbo. said:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=255158 :) I did look at this but I have a new straight-cut A+ gearbox ready and waiting, am I right in thinking I wouldnt be able to put that A block on my A+ box. |
17th Nov, 2008 at 02:38:15pm
Pretty sure the "A" and "A+" box/block combination can be mixed and matched? |
17th Nov, 2008 at 03:00:08pm
i would agree 74mm would leave it too thin, go with 73.5, and look at having some work done on the crank to bring up the cc |
17th Nov, 2008 at 03:01:51pm
A+ and A can be used together, but you need to to use either A+ or A drop gears. |
17th Nov, 2008 at 03:24:33pm
On 17th Nov, 2008 miniminor63 said:
A+ and A can be used together, but you need to to use either A+ or A drop gears. i've got sc A+ drops already too. |
17th Nov, 2008 at 03:30:04pm
Drop gears are specific to gearbox casing, it wont matter whether A or A+ bockes are used On 26th Oct, 2004 TurboDave16v said:
