| Home > Help Needed / General Tech Chat > intercooler positioning help needed | |||||||
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
17th Nov, 2008 at 10:00:15pm
Have enjoyed my evening mocking around the saab ic in the engine bay, have come up with two positions that seems to be ok…ish. What do you guys think?
internationally known as "big" swede |
17th Nov, 2008 at 10:20:06pm
the first option seems more sensible to me. well ducted and shrouded in and possibly out (into the wheel arch?)
17th Nov, 2008 at 10:28:32pm
Thanks James, i haven´t made the plenum yet, but heres a couple of sc pics, outlet will facing backwards, air inlet is facing the ic, i will probably turn the compressor housing another "click" to make it point slightly upwards. Sc is riding high in the pics, will be a couple of cm lower when the bracket is done.
17th Nov, 2008 at 11:23:44pm
Just be careful that rad doesnt throw too much hot air into the intercooler making an interheater |
18th Nov, 2008 at 12:19:43am
You'd be best to swap rad and intercooler positions around. If the IC was behind the rad then by the time the air reaches the IC it would be quite warm. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
18th Nov, 2008 at 12:42:43am
18th Nov, 2008 at 01:42:41am
dont mount it like it the first pic ......... you will suffer a massive heat soak and as Nic points out an interheater.
18th Nov, 2008 at 07:32:45am
Thanks boys, i have to sort another rad then, and sidemount it…about 30x30 cm or so. Mini one is to high for sidemount and mpi is probaby to long and have the outlets in the wrong places. Any tips of very small rads is welcome! Maybe i can sandwich two bike rads?
18th Nov, 2008 at 07:54:24am
I think your best option might be a charge cooler. There is just no space for a decent air to air IC under the bonnet. With a chargecooler you can put the rad somewhere else, and they are generally smaller than an air to air cooler. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Nov, 2008 at 08:53:22am
Wil, the saab intercooler fits in place of the mini rad, cores matches the grill almost perfectly :cool: If i fail to find a good side rad that works i will have a look into charge coolers, they seem to be a bit expensive and complex compared to a air/air ic though!
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
22nd Nov, 2008 at 02:19:46pm
all i'll say id AIR FLOW. |
22nd Nov, 2008 at 08:34:51pm
well, i have skipped the ic/charge cooler (for now) and will go progressive water/metty injection instead, probably devil system. Maybe i will run the engine on E85 later on, poor mans nitro!
27th Feb, 2009 at 09:00:56am
i´m going charge cooler anyway, heres some pics of my yamaha aeeros scooter rad, also a pic of the plenum with built in cooler that i will try to copy in steel 8-)
![]() 338 Posts Member #: 1911 Senior Member Swindon |
27th Feb, 2009 at 10:03:08am
is that a rotrex sc i see there? |
27th Feb, 2009 at 10:15:44am
yup internationally known as "big" swede |
27th Feb, 2009 at 10:19:25am
looking good mate :) tidy Drives
27th Feb, 2009 at 10:34:06am
I like it. I run a supercharger and I don't care the TB is on the wrong side.
27th Feb, 2009 at 11:43:33am
nice one is it the c15 model? they go for quite a bit brand new 1,500 if I'm not mistaken, how much did you pick it up for? I was planning on using one myself but found a t3 for 50 squid and realised turbo's the best idea lol. You gotta run an oil system through that aswell? you thought where you putting the oil cooler for it? Edited by quinton on 27th Feb, 2009. |
27th Feb, 2009 at 12:29:39pm
na it´s a C30 with 94 compressor (a bit big tbh), and it uses the engine oil instead of it´s own system as the late one does.
Edited by G13B on 27th Feb, 2009. internationally known as "big" swede |
27th Feb, 2009 at 02:18:16pm
That is a big bugger. Wow. Thought the engine oil was to thick for the SC. What psi you wanting to run up too? |
27th Feb, 2009 at 02:41:48pm
74 compressor would be optimal, but i guess you could have some more hp on top with the 94? Engine oil is ok, rotrex have their "own brand" that they charge stupid money for though! I think the charger maximum is 1,5 bar‚ don´t know what that is in psi?
27th Feb, 2009 at 02:50:35pm
On 27th Feb, 2009 G13B said:
No idea what i will se whit the pulley ratios i got, maybe i blow up the engine That's the TM spirit. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
27th Feb, 2009 at 03:28:07pm
1.5 bar is 21.75 psi |
27th Feb, 2009 at 07:49:20pm
Cool workshop 8-) |
27th Feb, 2009 at 08:54:57pm
