| Home > Help Needed / General Tech Chat > Subframe removal | |||||||
![]() 184 Posts Member #: 346 Advanced Member Portsmouth |
21st Nov, 2008 at 08:45:59pm
Hello all,
1310cc TWINK - T Conversion |
332 Posts Member #: 483 Senior Member Merthyr Tydfil |
21st Nov, 2008 at 09:21:42pm
It would make life easier to buy another 2 axle stands to support the front of you mini while you undo the subframe bolts and drop the frame from the car Use a piece of wood and balance the frame down with the jack -quite simply done-.. Plus its always handy to have 4 stands.
21st Nov, 2008 at 09:21:45pm
21st Nov, 2008 at 09:31:55pm
Thanks for the information, but the subframe metal has corroded away and wouldnt be happy reusing it TBH.
21st Nov, 2008 at 09:43:31pm
couple of axle stands, a length of wood between them both to spread the load over the floor.
21st Nov, 2008 at 11:49:13pm
21st Nov, 2008 at 11:57:51pm
On 21st Nov, 2008 Mr Mini said:
Also, finally can i fit this subframe to my car? Or is there a better one??? http://www.minispares.com/Product.aspx?ty=pb&pid=34330 I'd probably go for the Minispares one based on cost, but this one is better: http://www.foxwebsitedesign.co.uk/resource...suspennsion.JPG Isambard Kingdom Brunel said:
524 Posts Member #: 1380 Post Whore Swindon |
22nd Nov, 2008 at 12:22:47am
sorry the picture isn't great but this is how i took mine out.
Edited by Ollie on 22nd Nov, 2008. On 2nd Mar, 2008 joeybaby83 said:
neil_g, with all due respect, your the worse salesman on TM since rob_h tried to sell his own ass |
