| Home > Help Needed / General Tech Chat > T3 turbo , hybrid thaughts | |||||||
2nd Dec, 2008 at 08:52:29pm
Hi lads ,
2nd Dec, 2008 at 09:49:13pm
Ric, usuall upgrade to a escort cosworth ar housing on the T3 dont know what size that is
2nd Dec, 2008 at 10:00:13pm
Thanks steve.
2nd Dec, 2008 at 10:17:00pm
Am i right in thinking t3 tony is running 1380 ?, would that make a difference to the spool up as am just 1293
2nd Dec, 2008 at 10:57:11pm
only a tad in it
2nd Dec, 2008 at 11:04:51pm
On 2nd Dec, 2008 BENROSS said:
only a tad in it ric it the escort cossy T3 exhaust housing Infact, this is not correct as the Cossies used a T25 turbo. The ones used successfully in Minis are the RS Turbo one. On 13th Jul, 2012 Ben H said:
3rd Dec, 2008 at 12:08:51am
i stand corrected V
3rd Dec, 2008 at 12:21:35am
Is Vegard wrong??
3rd Dec, 2008 at 12:25:08am
i thought sierra cosworth came with T3, but could be wrong "Turbo's make torque, and torque makes fun"
3rd Dec, 2008 at 07:28:52am
sierra cosworth 3 door, and saph were t3 same as the escort rs turbo, but escort had a smaller housing of some sort.
3rd Dec, 2008 at 07:28:59am
Im sure it was t3 too.
Edited by MikeRace on 3rd Dec, 2008. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
3rd Dec, 2008 at 09:47:11am
either way, If I was in your shoes Ric, I'd not be looking for a T3, they are so old and things have moved on since. On 15th May, 2009 TurboDave said:
3rd Dec, 2008 at 11:19:52am
I have the 0.36 exhaust housing from the escort RS turbo and is what i recieved as a standard metro turbo from turbo technics as the smaller metro housing is no longer available for a re-con. -MINI CLUBMAN 1380 TURBO- |
3rd Dec, 2008 at 01:16:06pm
If you want to get technical the escort cos was atually a form of t34 with a larger compressor housing comparted to the sierra. The A/R on the turbine housing is 0.64 - very laggy even on the YB.
3rd Dec, 2008 at 07:46:53pm
On 3rd Dec, 2008 Jimster said:
either way, If I was in your shoes Ric, I'd not be looking for a T3, they are so old and things have moved on since. So any sugestions then jim. Im hoping for 180/200hp but would be nice if the turbo wasnt on its limit. I had an escort cosworth (t34) for 3 years and loved it , i actually enjoyd the lag, i then had a small turbo (t25) and hated it. You could drive the big off turbo but the later was allways wanting to go. I no a road car is different to a track/ hillclimb car and i could do with it on boost in every situation. I could have the down pipe modified to suit new turbo but ??? Rick Edited by cossierick on 3rd Dec, 2008. |
3rd Dec, 2008 at 09:48:18pm
I'm a big fan of the T25 range, I personally use a large 0.64a/r turbine housing one from a 200sx on my mini.
3rd Dec, 2008 at 11:45:18pm
4th Dec, 2008 at 12:53:57am
What are the benefits of the RST ex housings over the normal T3 ones then?
4th Dec, 2008 at 01:13:16pm
The RS Escort housing has the same 5 bolt wastegate fittings as the metro unit, so the wastegate off the metro can be moved accross and you can use the same elbow.
4th Dec, 2008 at 02:25:48pm
Thanks for the info, I eventually will get a more modern, better spec turbo but not just yet, the standard t3 is all on and plumbed in so i'll have a fiddle later down the line, while keeping and eye out for a cheap rst t3 to switch with! |
4th Dec, 2008 at 03:33:48pm
On 3rd Dec, 2008 joeybaby83 said:
i thought sierra cosworth came with T3, but could be wrong Yes, but no one ever mentioned Sierras.... On 13th Jul, 2012 Ben H said:
