| Home > Technical Chat > Zero deck or not? | |||||||
![]() 184 Posts Member #: 346 Advanced Member Portsmouth |
3rd Dec, 2008 at 06:00:34pm
1310cc TWINK - T Conversion |
3rd Dec, 2008 at 06:06:29pm
the squish effect will suffer if they are down the bore, that said 0.5 mm isnt much.
Edited by miniminor63 on 3rd Dec, 2008. |
3rd Dec, 2008 at 06:10:53pm
On 3rd Dec, 2008 miniminor63 said:
the squish effect will suffer if they are down the bore. that said, 0.5 mm isnt much. But why do you want that low a CR with a K head. The chamber in that is more effective, and you will probably run a programable ECU so you can gain driveability and power with a higher CR. Sorry miniminoe63! Thats gone well over my head! 1310cc TWINK - T Conversion |
3rd Dec, 2008 at 06:27:28pm
around the outside of the piston there is what is known as the "squish band" at tdc this approaches the face of the head (unless the head has been cut away to lower cr) and squishes the mixture toward the middle of the cylinder, this agitation of the mixture causes a more compete burn.
3rd Dec, 2008 at 06:36:29pm
i know its abit 6 of one half a dozen of the other (and im no expert)
3rd Dec, 2008 at 06:42:44pm
What about flat top pistons - are these rubbish at squish then? 1310cc TWINK - T Conversion |
326 Posts Member #: 1323 Senior Member |
3rd Dec, 2008 at 06:47:20pm
Is the squish area that important with a pent-head and forced induction ?
3rd Dec, 2008 at 06:53:28pm
dont know Carl, but looking at the standard BMW K engine it has a large squish band on the head itself. (there is a large flat area around the chamber but inside the bore), I guess its there for a reason. |
3rd Dec, 2008 at 06:59:46pm
Ah I see what your saing 63, JohnK said the same thing. Not questioning the logic just interested in learning more about it.
3rd Dec, 2008 at 07:01:32pm
carl,
3rd Dec, 2008 at 07:02:58pm
also i read a bit on 5 valve heads that said it was very dificult to get enoiugh squish area in comparison to a 4 valve head. On 28th Aug, 2011 Kean said:
3rd Dec, 2008 at 09:05:07pm
A strange question but...
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
4th Dec, 2008 at 12:55:28am
now there's a thought!
4th Dec, 2008 at 02:42:08pm
not a very good picture, but you can see the squish band on the K head chambers. A matching squish band on the piston will generate the turbulance in the charge that the squish theory says. I'm going with it On 26th Oct, 2004 TurboDave16v said:
4th Dec, 2008 at 02:48:54pm
On 4th Dec, 2008 1972-ANGUS said:
now there's a thought! it would be very difficult eh? Ive often wondered this myself, as i suspect, has anyone who have cut a head. This "Squisshy Fissshy" test would have to test compression ramp as such, not a total compression calculation which is just based on cc. But this would not evaluate the eveness, or the localisation of the mixture which leads to det. Any ideas any of you bright sparks out there Regards Colin Its allready been done, its called a glass engine ( its not actualy glass, but Saphire) this engine is a single cylinder engine that has a cylinder that is clear, and the crown of the piston is clear, cameras are positioned under the crown and around the cylinder. cylinder pressures are monitored and the flame front is monitored. There are other engines that have pressure sensors in the crown of the pistons to measure locality pressures. Its all there but it really is experimental stuff, well out the reach of us amature engine builders. I would be tempted to go with the text books, as these are the guys that have been there and done that, and have the letters after their names to prove it :) On 26th Oct, 2004 TurboDave16v said:
4th Dec, 2008 at 03:10:24pm
Iv been doing a fair bit of reading on the quench and the squish. I know its sad but I was facinated by it! 1310cc TWINK - T Conversion |
4th Dec, 2008 at 03:26:54pm
Infact 1mm + 0.5 = 1.5mm Doh.
4th Dec, 2008 at 03:44:48pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=229847 On 26th Oct, 2004 TurboDave16v said:
4th Dec, 2008 at 03:59:48pm
Is that offset 1380? (does offset only apply to 1380..?)
4th Dec, 2008 at 04:01:56pm
On 4th Dec, 2008 Mr Mini said:
Is that offset 1380? (does offset only apply to 1380..?) Did you keep the original front 3 stud fixing holes in the block, or are all 10 in new positions? Tidy job on the block. Chris. Did you not read the first post in the topic I posted above? It is offset bored to line uo the cylinders center to center, liners fitted to bring it back to 1275cc, then ALL the head studs were relocated to line up the head chambers with the cylinders. its as good as the bike engine! Edited by Sprocket on 4th Dec, 2008. On 26th Oct, 2004 TurboDave16v said:
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
4th Dec, 2008 at 04:56:25pm
Oh pap. I have my pistons about 70 thou down the cylinder. Plus 25 thou HG. 1062cc engine with k100 8 valve head. Will it be ok? |
5th Dec, 2008 at 08:49:06am
miniboo im not expert! but 95thou sounds quite a lot. Saying that it might be fine iv heard people run big quench distances with no det problems.
5th Dec, 2008 at 11:55:16am
Would the extra effort be worth the cost, for the results. I dont think so.
1425 Posts Member #: 690 Post Whore Norfolk |
5th Dec, 2008 at 01:29:06pm
Don't forget the cut outs in the MED pistons are designed to clear oversize valves as well,wink,wink
If Carling made Mini engines
