| Home > Help Needed / General Tech Chat > Removing press fit pistons without damaging pistons | |||||||
7th Dec, 2008 at 01:10:46am
gonna try and remove the slipper pistons off my 998's rods tomorrow, anyone have any advice?
7th Dec, 2008 at 07:33:33am
The way I did it with the 1275 interference fit pins (without having access to a press :( ) was by making up a puller.
Edited by Rod S on 7th Dec, 2008. Schrödinger's cat - so which one am I ??? |
7th Dec, 2008 at 09:28:27am
Hi
7th Dec, 2008 at 11:17:58am
if the pistons are slipper style somthing like this will work.
7th Dec, 2008 at 11:38:36am
rod, on the 998 the slipper pistons have a nice flat ring aroud the pin
7th Dec, 2008 at 12:05:12pm
lol,
7th Dec, 2008 at 12:31:57pm
On 7th Dec, 2008 joeybaby83 said:
rod, on the 998 the slipper pistons have a nice flat ring aroud the pin There you go then, do it just like Joe says, no need for my fancy shaped bit of hardwood. Schrödinger's cat - so which one am I ??? |
7th Dec, 2008 at 01:43:45pm
Not tried taking press ftr pistons off yet,but just about to for an A+ engine I am starting to build. I always felt thet heating the little end was a bit dodgy and had visions of the rod snapping later and totalling the engine, so I will go the puller route.Once you have made the bits you will always have them.I have a box full of home made special tools, most of which I have only used once ! |
7th Dec, 2008 at 02:49:32pm
7th Dec, 2008 at 05:47:49pm
There are no issues with heating the rod up to get the interference fit pins in and out, just allow them to air cool afterwards.
