| Home > Help Needed / General Tech Chat > gt17 turbo + 5 speed gearbox | |||||||
8th Dec, 2008 at 11:06:34pm
after reading some recent posts about the T3 turbos they seem to be a thing of the past, i know a few people are using the gt17 turbo and posibly others.
8th Dec, 2008 at 11:24:04pm
paul , the gt17 is used on the saab 9.5 and gets changed on the upgrade kits at about 265 bhp ,so i think itll prob flow well over the requirement for a 5 port .
8th Dec, 2008 at 11:24:36pm
You can get over 150bhp with a standard t3. |
10th Dec, 2008 at 12:46:14am
i know you can get over 150 with a standard t3 but its abit old skool, i thought it might be quite cool to use a newer turbo on a 5port. :)
10th Dec, 2008 at 07:50:32am
Makes sure you've got a cup or tea and several spare hours before you start reading this:
10th Dec, 2008 at 10:49:05am
I have a 5 speed in the daily 1380 and I must say its a dream It is a MS evo 5 speed set and as yet with 4800miles and 100+ hp no problems at all the yoke has eatn trusts savaged drop gears blown diff pins but the box has survived the lot I have the 3.44 diff in it which is great because you get all the advantages of 3.44 in 1,2,3 and 4th with all the advantages of 3.00 in 5ft I would say that it might struggle with the torque of a turbo though my motor is a 1380 na. on the hole my experience with this box has been very good. On 17th Feb, 2009 Rob H said:
10th Dec, 2008 at 08:54:43pm
this will be my evenings reading :). got a few other posts favorated from the gt17 search. thank you rob.
On 10th Dec, 2008 Rob H said:
Makes sure you've got a cup or tea and several spare hours before you start reading this: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10263 thanks for that about the 5 speed, i was not so sure about it being able to hold up to the torque of the turbo motor, have you got any pics of the box? do they use the same 1,2,3,4 gears from a 4 speed, with a modded gearbox housing for the 5th? On 10th Dec, 2008 PaulH said:
I have a 5 speed in the daily 1380 and I must say its a dream It is a MS evo 5 speed set and as yet with 4800miles and 100+ hp no problems at all the yoke has eatn trusts savaged drop gears blown diff pins but the box has survived the lot I have the 3.44 diff in it which is great because you get all the advantages of 3.44 in 1,2,3 and 4th with all the advantages of 3.00 in 5ft I would say that it might struggle with the torque of a turbo though my motor is a 1380 na. on the hole my experience with this box has been very good. Drives
11th Dec, 2008 at 12:13:09am
444 Posts Member #: 2885 Senior Member |
11th Dec, 2008 at 12:26:39am
I just lost my whole evening to that GT17 thread!
11th Dec, 2008 at 12:51:49pm
not sure about the turbo site of things, i no nothing about the moden stuff, the grearbox side of things your on about a S/C type i guess, not sure what the S/C can take but i know it's a big NO, NO for a normal 5 speed box. Best 1/4 mile 13.2 seconds @116 mph
12th Dec, 2008 at 02:36:06am
the standard T3 is peaking around 170 BHP then it declines the MAPS i have seen.
