Home > Help Needed / General Tech Chat > More bike carbs questions.
Alex1340
Member #: 111
Loughborough
Hi Guys, got hooked on the bike carb idea now. bit question is.. i have a brake servo do need to link the two inlets to get the vacuum for it? also i have a map sensor on the mega jolts, will that need to link the inlets and have a small chamber to equalise pressure?
Does any one know the angle at which the carbs need to be?
Thanks
slater
Member #: 1291
Suffolk / Birmingham
You dont ned to link the inlets for the servo, not sure about the MAP tho.
Alex1340
Member #: 111
Loughborough
Arrr ok. So I can run It from the closest inlet.
I know on my friends zetec mk2 escort all four cylinders need to be connected and then in to a chamber to even out the vacuum.
You'll at least need to join them together for MAP. You may well need to use TPS for engine load as you won't get a good map signal low down.
Edited by Bat on 22nd Dec, 2008.
hario
Member #: 2885
joining them together is surely the better idea, resulting in the sensor taking a better average of whatever the reading is..
What carbs are they? google the bike they came from and take an educated guess..
or take a protractor to the same model bike at a bike show!
