Home > Help Needed / General Tech Chat > cold ass car
stockodaz
Member #: 4055
teeside
hi could someone tell me what makes a car a coldass when first started i have to start mine and let it warm up for a few minutes otherwise its a spluttery dog there not like that when new and was wondering if there was any parts i could buy to cure problem or is it just the fact its a 25 year old worn engine its a first time starter and excellent runner any help much appreciated and can i wish everyone a merry xmas
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Perhaps a good service & setup might cure it.
On 19th Jan, 2010 wil_h said:
Sounds like it's weak to me? Start with the advice above then go from there :)
what year is the car?
is it any better/worse with the choke on?
stockodaz
Member #: 4055
teeside
hi my car is an f reg mini with a b reg metro turbo engine car starts fine with a little choke on the morning car is running brilliant its just when its cold its very spluttery when driven until it warms up i need to leave it for a few minutes ticking over ive had fuel mixture set up by my local mot garage
stockodaz
Member #: 4055
teeside
forgot to mention car has had good service only thing not renewed was plugleads
Jason G
Member #: 1459
En-suite user
Braintree, Essex
You know what your top priority is then? :)
my guess its set up for MOT emissions they will have made it mega lean.
richen it up halfe a turn by screwing the mixture screw in, see how you go from there ?
of course make sure the engine parts plugs lead etc .... are not clapped out as the guys state above.
you may be used to a modern engine with auto choke, a short cold snap under 10deg C highlights this problem with the choke both my cars are the same
stockodaz
Member #: 4055
teeside
thanks for help yes my car was set for mot emmisions cheers benross
