Home > Help Needed / General Tech Chat > help turbo head leaded or unleaded how do i tell??
jonboyturbo1
Member #: 4701
south wales, cwmbran
hi this has prob been brought up before? just bought metro turbo engine was just wondering how do i tell if its leaded or unleaded? cheers
You need the engine code AFAIK. I don't think there were any unleaded turbos?
jonboyturbo1
Member #: 4701
ok cheers, thought i read sumwhere that the last lot of metros were unleaded
The last of the Metros may well have been, but that doesn't mean the last of the "A" series turbo were.
But, TBH, the way parts have been swapped over the last 20 years, the only way you will know on your own cylinder head is to look at it... closely :)
jonboyturbo1
Member #: 4701
wat am i lookinig for lol, also is it only the head that makes it leaded or unleaded? cheers
evolotion
Member #: 83
Glasgow, Scotland
its only a part in the head that makes it suitable for unleaded fuel
Edited by evolotion on 30th Dec, 2008.
Denis O'Brien.
literally just the valve seats, youll have to whip the valves out and take a look, a quick search on google will show you waht to look for
jonboyturbo1
Member #: 4701
cheers guys, will go look now
all turbo heads i have done i have not found any hardend seats in
you will find hardend inserts in the exhausts not the inlets on some post 89 metro engines with 33mm inlet valves
but .... not on turbo heads.
i can fit inserts for you if you wish please pm me
