Page: |
Home > Technical Chat > The 500 and 731/800 kent cams | |||||||
2nd Jan, 2009 at 10:55:05am
Have a look at the MD274.
520 Posts Member #: 2093 Post Whore Grenoble, France |
2nd Jan, 2009 at 06:35:49pm
Bat:
Edited by alpa on 2nd Jan, 2009. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
5th Jan, 2009 at 10:35:34pm
I'm attaching the profiles because my Internet provider is putting me out.
Edited by alpa on 5th Jan, 2009. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
9812 Posts Member #: 332 Resident Cylinder Head Modifier Mitsi Evo 7, 911, Cossie. & all the chavs ...... won no problem |
6th Jan, 2009 at 12:15:21am
MD266 has a good point: higher exhaust than intake lift. Unfortunately intake is not well located (I think) for a turbo application.
6th Jan, 2009 at 02:42:18am
On 6th Jan, 2009 BENROSS said:
one quote:- of a well known A series tuner stated use a 731 cam and loose all the bottom end and gain very little in the middle and Gain almost nothing at the Top! Was it on a turbo engine ? On a N/A this would be understandable because IC is late but overlap is low, so you loose torque (IC) but don't fully take advantage of a tuned exhaust (overlap). Now I realize that on a N/A this cam is a nonsense unless you want a green catalized engine with a kick at 4000 RPM (which is a nonsense on an old 2v). Even for turbo it may be a wrong choice if one wants a classic torque curve with a max at 3500. For fun I prefer high rev turbos like Maserati Ghibli 2L. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
6th Jan, 2009 at 08:12:22am
a list of Kent can dealers can be found here http://www.kentcams.com/
11046 Posts Member #: 965 Post Whore Preston On The Brook |
6th Jan, 2009 at 10:59:45am
I ran the Kent MD274 cam in the 1400 with 1.5:1 ratio rockers and it gave 100bhp at 6800rpm and 87lbft at, I cant for the life of me remember That was on a standard production ECU which was a little conservative at best.
315 Posts Member #: 3013 Senior Member Epsom Surrey |
6th Jan, 2009 at 09:22:49pm
i ran a old mg metro cam in mine at 1st running around 18 psi and it felt strong and revved round to 6500 easy n felt liek it was still pulling well
7763 Posts Member #: 74 I pick holes in everything.. Chief ancient post excavator |
6th Jan, 2009 at 10:55:07pm
On 6th Jan, 2009 DD_Racing said:
i ran a old mg metro cam in mine at 1st running around 18 psi and it felt strong and revved round to 6500 easy n felt liek it was still pulling well but i recently changed to a 266 and personally i thourght it lacked power!! it didnt feel as though it pulled as strong ok its only a minimal feeling of difference but a difference none the less Did you have the car rolling roaded afterwards? At what did you time the cam to? On 13th Jul, 2012 Ben H said:
6th Jan, 2009 at 11:14:49pm
the 266 should be timed in at 107deg ATDC
337 Posts Member #: 399 Senior Member Austria |
7th Jan, 2009 at 08:52:11am
I thought the MD266 should be timed in at 106deg ATDC? |
7th Jan, 2009 at 02:19:29pm
i timed my one in to kent cams spec which is 106 deg |
7th Jan, 2009 at 04:34:09pm
On 7th Jan, 2009 DD_Racing said:
i timed my one in to kent cams spec which is 106 deg What did the Rolling road after the camchange say? On 13th Jul, 2012 Ben H said:
7th Jan, 2009 at 06:27:03pm
There is thought that if you time a cam into, say, 107 degrees, using a new chain, it will achieve 106 degrees when the chain has bedded in :) On 26th Oct, 2004 TurboDave16v said:
7th Jan, 2009 at 07:12:32pm
On 7th Jan, 2009 Sprocket said:
There is thought that if you time a cam into, say, 107 degrees, using a new chain, it will achieve 106 degrees when the chain has bedded in :) Other way around surely Sprocket, or am I having a bad night ??? Schrödinger's cat - so which one am I ??? |
6274 Posts Member #: 509 Post Whore Isle of Man |
7th Jan, 2009 at 07:22:29pm
dont they stretch out by about 3 degrees after a few miles? thats what has been recommended to me anyhow "Turbo's make torque, and torque makes fun"
7th Jan, 2009 at 07:45:24pm
There is thought that if you time a cam into, say, 107 degrees, using a new chain, it will achieve 106 degrees when the chain has bedded in :) Other way around surely Sprocket, or am I having a bad night ??? Probibly, never actualy thought about it as I typed it On 26th Oct, 2004 TurboDave16v said:
7th Jan, 2009 at 07:45:49pm
On 7th Jan, 2009 joeybaby83 said:
dont they stretch out by about 3 degrees after a few miles? thats what has been recommended to me anyhow Chains dont streach, they wear On 26th Oct, 2004 TurboDave16v said:
7th Jan, 2009 at 07:50:13pm
I went for 1 degree (for potential new chain stretch) but my logic was the cam follows the crank so with the AFTER TDC cam reading for measuring the inlet valve lift, I set mine at 105 degrees assuming it will stretch to 106...
7th Jan, 2009 at 08:49:47pm
well with the 266 my car made 107hp on 6 psi on the rolling road with 1.5 roller rockers and 8.2.1 compression and my own ported head!!
7th Jan, 2009 at 10:07:13pm
well with the 266 my car made 107hp on 6 psi on the rolling road with 1.5 roller rockers and 8.2.1 compression and my own ported head!! i dont know what it made with the mg metro cam though as i never dynod it with that in. There you go. That might be the reason for it feeling not as good. It wasn't setup On 13th Jul, 2012 Ben H said:
152 Posts Member #: 1074 Advanced Member Northamptonshire |
8th Jan, 2009 at 06:37:48pm
Does anybody know the spec of these cams?
8th Jan, 2009 at 07:04:17pm
well i didnt do any settin up on the dyno that was just quickly put it on and see how much power???
8th Jan, 2009 at 08:01:37pm
On 8th Jan, 2009 DD_Racing said:
im happy..lol well, with no comparitive data, v certainly wont be! "Turbo's make torque, and torque makes fun"
8th Jan, 2009 at 09:57:43pm
well i personally prefer the mg metro cam but hey every one has there own opinions and views |
Page: |
