Home > Help Needed / General Tech Chat > Is mine a Metro Turbo engine? 12HC16AA.1C3916
mpe
Member #: 4743
Folks,
A while ago I bought a complete engine / transmission with all of the turbo bits on it. It's now installed, and getting close to being a going concern, so I thought I'd find out if I have an unleaded engine. Lo and behold, the two or three websites I've been to on the subject of engine numbers suggest that this isn't a turbo engine, but a HLE.
Can anyone kindly clarify for me?
If it's not a turbo donk, I'll be shocked and surprised - I'll have been had!
What is a HLE? (I'm in Australia, that's not an acronym we used here).
Thanks all.
Matt
edited. My bad:
Search for : 12HC16AA on this site....
Edited by turbodave16v on 11th Jan, 2009.
On 11th Jan, 2009 TurboDave said:
edited. My bad:
that just brings me back here *happy*
HLE is a high spec Metro. Had a 9.4:1 CR standard 1275 fitted.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Matt.
Assuming the head has never been off and is the original, the question of 'is it a turbo engine' could be answered by taking the rocker cover off and checking that the exhaust valve stems are larger than the inlets (they are bigger on turbo engines as they are filled with Sodium).
If not, then it don't sound like a turbo lump.
It doesn't help with answering whether it's unleaded though, you'll need to do some more searching on TM for that.
Good luck.
Rich.
AFAIK there weren't any unleaded turbo engines. The later N/A metros were U/L but not the turbos.
mpe
Member #: 4743
Thanks for the replies folks.
I'll whip the rocker cover off and look for the large diameter exh. valves.
as for the unleaded bit, I'll see how much it'll cost to add the lead from a bottle. no cat converter, so nothing to wreck, except my wallet.
cheers all.
On 12th Jan, 2009 mpe said:
......so nothing to wreck, except my wallet......
Be carefull which lead additive you use, there are about three different base metals used as the alternative to lead in the substitutes and one has a reputation (although not scientifically proven) of causing high erosion rates on turbine wheels.
I can't remember which, but it's the less commonly used one.
metroturbo
Member #: 989
North Yorkshire
There were no unleaded turbos from the factory. They stopped producing them when cars had to be unleaded compatible (January 1990 onwards).
Edited by metroturbo on 12th Jan, 2009.
dan_up
Member #: 1835
Thame, oxfordshire
i have a turbo lump with the same engine number, so i guess.....yes, type it in on google, quite a bit of info about it.
On 23rd Aug, 2010 Nic said:
Turbophil had a butt plug made that seemed to be suitable. He may have finished with it now and have it kicking around spare
metroturbo
Member #: 989
North Yorkshire
12HC16AA is a Metro Turbo Engine taken from a 1985-1988 Metro Turbo.
