| Home > Beginners Tech > Megajolt & Fuel Pumps | |||||||
13th Jan, 2009 at 08:13:36am
I've had a search, but can't find anything specific about what I'm thinking about.
13th Jan, 2009 at 08:38:53am
should work,
13th Jan, 2009 at 08:42:44am
Thanks.
13th Jan, 2009 at 08:46:23am
It's a good idea, it would be standard with a full EMS.
13th Jan, 2009 at 09:15:32am
Escort XR3i fuel pump relay now on my shopping list If something is worth doing, it's worth doing half of. |
13th Jan, 2009 at 09:22:25am
That's a good thread. Thanks
13th Jan, 2009 at 09:28:43am
On 13th Jan, 2009 apbellamy said:
Does the inertia swtich just go inline between the relay and the pump? I'm guessing I can use one from any car as long as it's 12v. It does on all cars I've worked on. It certainly does on an MPI as I have the wiring diagrams on my screen as I speak :) They quite often come up on eBay (usually advertised for kit cars) if you don't want to crawl around a scrappy in this weather. Schrödinger's cat - so which one am I ??? |
13th Jan, 2009 at 09:38:18am
I like scrappys and I keep meaning to find an excuse to go to one...
13th Jan, 2009 at 06:58:30pm
Would I be better putting the inertia switch before the power to the MJ (with the MJ controlling the pump)? That way it kills spark and fuel if/when I have a bump? On 11th Feb, 2015 robert said:
13th Jan, 2009 at 07:12:18pm
wouldnt hurt,
13th Jan, 2009 at 07:31:01pm
Makes sense to me! If something is worth doing, it's worth doing half of. |
13th Jan, 2009 at 07:43:36pm
Would I be better putting the inertia switch before the power to the MJ (with the MJ controlling the pump)? That way it kills spark and fuel if/when I have a bump? Most microprocessors don't like having their power killed for no good reason - some object in a most extreme way (ie, they die...). The float full of fuel isn't the issue, the reason inertia switches got invented was because of high pressure (ie, fuel injection) pumps potentially still running after a major impact. A decent injection fuel pump could put more fuel on the road in a couple of seconds, and again, and again, and again... until the tank eventually runs dry... than you SU's float bowl ever could. It's the pump you need to stop with the inertia switch, not the electronics :) Schrödinger's cat - so which one am I ??? |
13th Jan, 2009 at 07:50:35pm
Maybe another use for one of the other programable outputs... On 11th Feb, 2015 robert said:
13th Jan, 2009 at 09:04:02pm
Doesn't switching the ignition off kill the power instantly, in the same way an inertia switch would?
On 13th Jan, 2009 Rod S said:
Most microprocessors don't like having their power killed for no good reason - some object in a most extreme way (ie, they die...). |
13th Jan, 2009 at 09:15:56pm
Good point. I would like to kill the engine instantly in the event of a bump and not leave it running the float bowl out. If something is worth doing, it's worth doing half of. |
13th Jan, 2009 at 09:43:19pm
I would say so. Looking at the diagrams on here, you just have the 2 +ive wires from a switched live fuse. If the ignition goes of, power get's cut to the MJ. Inertia switch should do exactly the same thing, but with a bump instead of the key...
On 13th Jan, 2009 metroturbo said:
Doesn't switching the ignition off kill the power instantly, in the same way an inertia switch would? On 13th Jan, 2009 Rod S said: Most microprocessors don't like having their power killed for no good reason - some object in a most extreme way (ie, they die...). On 11th Feb, 2015 robert said:
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
13th Jan, 2009 at 09:51:28pm
whats wrong with just putting the bump switch on the powder feed to the pump??
13th Jan, 2009 at 09:55:04pm
My plan for the wiring was to take a fair sized wire from the fuse box on a switched live circuit to power the relay box (daisy chained between the relays). It sounds like this wire is the best place to put the inertia switch.
13th Jan, 2009 at 09:56:25pm
On 13th Jan, 2009 1972-ANGUS said:
whats wrong with just putting the bump switch on the powder feed to the pump?? have i missed something?? On 11th Feb, 2015 robert said:
13th Jan, 2009 at 10:17:02pm
There's still plenty of fuel in the carb float bowl and fuel lines, so I'm looking at stopping ellectircal stuff which could make a spark and a resulting big bang
On 13th Jan, 2009 1972-ANGUS said: whats wrong with just putting the bump switch on the powder feed to the pump?? have i missed something?? Good stuff, you have it planned out well. however, i would still just put the bump switch on the way to the pump. this will be tripped more often then an accident if it is on the road. (it would here in ireland anyway) and work a diff solution for the lccy feed. its just that the megajolt might not live longer then a few accidental trips over an unseen speed bump. Regards Colin |
13th Jan, 2009 at 11:08:46pm
My point was (and remains) that inertia switches were "invented" to shut down high pressure fuel pumps in the event of an accident to stop fuel being sprayed around at high pressure.
14th Jan, 2009 at 07:54:17am
Sounds like I just need to kill the tank then, as killing the rest of the ellectrics might not work and may well just kill the switch etc.
14th Jan, 2009 at 11:05:43am
Thanks. If I used the oil preasure switch wire would that not just give power when there's oil preasure (oil presure = completed circuit??)? Or have I got that completly wronng? Yes that's why 99% of people do it, so if you crash, you lose oil pressure and it cuts the fuel pump. Quite a few posts on it, do a search. You're best using a metro oil pressure switch as it works the opposite to a mini one. |
14th Jan, 2009 at 11:34:51am
That's fine as long as you're engine stops and you're oil preasure drops....
Thanks. If I used the oil preasure switch wire would that not just give power when there's oil preasure (oil presure = completed circuit??)? Or have I got that completly wronng? Yes that's why 99% of people do it, so if you crash, you lose oil pressure and it cuts the fuel pump. Quite a few posts on it, do a search. You're best using a metro oil pressure switch as it works the opposite to a mini one. On 11th Feb, 2015 robert said:
14th Jan, 2009 at 11:42:17am
That's why we have an inertia switch too :) |
