Home > Help Needed / General Tech Chat > Arrrh!! Any ideas?
998turbomini25
Member #: 2276
sheffield / derby
Right basically I've just rebuilt my engine got it put back together fitted it in the car and i was just fitting the last fuel hose, when the screw from the stainless hose clip fell out and dropped straight down the dipstick hole. (what are chances)*surprised* This obviously needs to come out but cant really see how without takeing the engine apart, has anyone got any ideas?? *Confused*
drop the oil with the wives vegetable seive to catch it, failing that whip off the speedo cover and have a good rummage about?
drop the oil and hope it comes out :(
stainless can be magnatised? drop a extendable magnet down there have a try getting it back? if you have a magnetic oil trap for your drain plug, jack one side of the car up and then the back and get it on there if possible :) jobs a gooden
either way jack the side of the car up first, try and get it moving to one side, preferably the passanger side you jack up lol
Edited by Paul R on 13th Jan, 2009.
Jack up the back n/s corner, leave over night and drain it out
I did a similar thing years ago:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=1911
998turbomini25
Member #: 2276
sheffield / derby
cheers guys for the imput, i will be going on a small fishing expedition tomorrow hopefully with some success will let you know. ive tried a magnet on an identical bolt and its deffinatly stainless and not magnetic
Edited by 998turbomini25 on 14th Jan, 2009.
998turbomini25
Member #: 2276
sheffield / derby
Well its out!! In the end i used a henry hoover and some small bore pipe which after some messing about finally sucked the bolt up i didnt have any oil in the sump when i dropped the bolt so i couldnt drop the oil. so i resorted to fishing with a hoover and an led on a piece of wire so i could see what i was doing whilst looking through the oil drain hole.!! took some time but the main point is its out now *smiley* so i can continue putting the finishing touches on the car and hopefully start it soon.
its just a standard 998 for now but i have a new gt15 sitting on a shelf and im half way through building a manifold for it.
luke
well donw:)
well done, now FFS put the dip stick in!
you dipstick!
jamesfawcett
Member #: 218
Bingley, West Yorkshire
good old henry!
