| Home > Help Needed / General Tech Chat > rear shocker mounts? | |||||||
18th Jan, 2009 at 05:52:31pm
ive got a knocking noise from me rear shockers and i think, well im sure ie got an extra washer in there:$ can anyone confirm the order looked in haynes doesnt really show much.
18th Jan, 2009 at 06:32:42pm
Top one.
Own the day
18th Jan, 2009 at 06:33:32pm
Do you really need a washer in between the body and the rubber on either side?
18th Jan, 2009 at 07:06:35pm
Keeps it all in line when the shock changes angle through its travel. Own the day
18th Jan, 2009 at 07:47:38pm
i dont think i need the washer above the body. there lowerd shockers and if i just bounce the rear of the car you cn feel/hear it so there not bottoming out. no longer a series, but still 1.3 turbo.
203 Posts Member #: 479 Senior Member |
18th Jan, 2009 at 08:06:59pm
do you have hi los?
18th Jan, 2009 at 08:07:35pm
Edited by Bat on 18th Jan, 2009. VEMs Authorised Installer / Re-seller. K head kits now available!
18th Jan, 2009 at 08:15:44pm
On 18th Jan, 2009 Timinichelsea said:
do you have hi los? it may be the hi los bottoming out on the cones. If it is then you have to get the cones machined its defo the shockers knocking, im gonna try taking a washer or two off. thanks no longer a series, but still 1.3 turbo.
18th Jan, 2009 at 10:20:50pm
On 18th Jan, 2009 Bat said:
Hi, Nut Nut ( if you must have 2 )
Washer Rubber Body Rubber Washer That's how it is in the Rover MPi w/shop manual. Cheers, Gavin :) I agree |
18th Jan, 2009 at 10:35:59pm
Washer Rubber Body Rubber Washer That's how it is in the Rover MPi w/shop manual. Cheers, Gavin :) see this is what makes sence to me as well, i just dont understand where or when i fitted all the extra washers tho lol no longer a series, but still 1.3 turbo.
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
18th Jan, 2009 at 11:06:09pm
I've been through all this too, never did solve the annoying nocking. |
19th Jan, 2009 at 12:05:59am
What shocks you got fitted. Own the day
19th Jan, 2009 at 12:24:37am
i had this same thing......mine was easy though.....i actually tightened the nuts up after fitment....forgot about them and had already fitted the tank!
19th Jan, 2009 at 06:18:13pm
I have had similar knocking and it turned out to be the lower mounts that had loose nuts so - are the bottom bushes OK too? |
19th Jan, 2009 at 08:22:15pm
there spax adjustables. the lower nuts are tight and bushes ok. no longer a series, but still 1.3 turbo.
19th Jan, 2009 at 10:40:59pm
Washer Rubber Body Rubber Washer That's how it is in the Rover MPi w/shop manual. Cheers, Gavin :) I agree Me too! On 13th Jul, 2012 Ben H said:
