Home > Beginners Tech > how much to skim to raise cr to around 11:1?
welshdan
Member #: 1111
s wales
hi all, im looking to modify my mpi cooper. will be doing a few bits and pieces to the engine. have a spare head, which i will recondition, and port and polish.
i know that the cooper works conversion ran around 10:1 cr. am hoping to raise my head (with standard size valves ) to around 11:1.
how much do i need to get skimmed off? also, at what point will 1.5 ratio rockers make the valves hit the pistion tops?
cheers
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I believe Veragrd once said that every 12 thou resulted in 1cc. This was in relation to a 12G202 if I remember correctly. It's a good starting point though. You could use this as a guideline and take a bit too much off the head. Then grind out the chambers a little to get them where you want
On 30th Apr, 2010 Rod S said:
Gary's description is best
How are you going to correct the ignition timing when you raise the compression?
welshdan
Member #: 1111
s wales
how high can the compression be raised on standard timing?cheers
GaryOS
Member #: 2810
Dublin, Ireland
Depends on your fuel octane rating. You would also need to know what CR it's running at now. Off hand, 11:1 sounds like alot for the ignition map of a standard MPI
