| Home > Help Needed / General Tech Chat > Back-tracking | |||||||
![]() 184 Posts Member #: 346 Advanced Member Portsmouth |
1st Feb, 2009 at 09:31:06am
1310cc TWINK - T Conversion |
1st Feb, 2009 at 10:07:26am
i'd just undo the one head stud that is touching without disturbing any of the others, trim a bit off the end (unless it will screw into the block further) then re intall it an torque it up. On 28th Aug, 2011 Kean said:
1st Feb, 2009 at 10:33:16am
I can grind down the top of the stud that is touching - without having to undo the ARP nut. Do you think I should leave it insitu while I grind it down?
Edited by Mr Mini on 1st Feb, 2009. 1310cc TWINK - T Conversion |
1st Feb, 2009 at 11:08:46am
have a look at this website if do not already have it
1st Feb, 2009 at 11:32:54am
On 1st Feb, 2009 Mr Mini said:
.....but will grinding down the stud cause to much vibration down into the block and unsettle the thread sealant (however bearing in mind the nut will be fully torqued up). IMHO no, not if it's fully torqued. To be certain, recheck the torque before grinding (check torque wrench clicks with no movement of nut) and do same again afterwards... if it tightens slightly further afterwards, then something has moved, but I think it is highly unlikely anything will. On 1st Feb, 2009 Mr Mini said:
....But I could undo this nut, grind down the ARP washer and reinstall. How would you grind it flat and parallel ??? Edited by Rod S on 1st Feb, 2009. Schrödinger's cat - so which one am I ??? |
1st Feb, 2009 at 11:42:56am
Good question Rod S!
1st Feb, 2009 at 11:52:19am
1st Feb, 2009 at 12:07:16pm
Yes I had my engineering shop remove 3mm from each stud.
1st Feb, 2009 at 12:23:57pm
to be honest. i wouldnt be grinding anything in situ. how would you keep the swarf out from the moving part or know you have got it all?? (isnt that right Paul S)
1st Feb, 2009 at 12:38:03pm
Trouble is, if I apply thread sealant to the stud, then insert it with the head in place, wouldnt the sealant ooze out and leave excess sealant on the block surface?
1st Feb, 2009 at 12:39:49pm
1st Feb, 2009 at 12:43:13pm
1st Feb, 2009 at 01:00:22pm
Good question Rod S! I was going to take it to my local engineering shop and see what they have to say. Do you think its possible? To answer that specific question only (ie, grinding a washer flat and parallel) any decent machine shop should have a surface grinder with a magnetic table, so providing the washer is magnetic, it's easy..... If they don't have a surface grinder with a magnetic table, then no..... I was thinking you might be considering doing it yourself :) However, from the other peoples responses, it's probably more than just the washer you need to think about...... Schrödinger's cat - so which one am I ??? |
1st Feb, 2009 at 01:10:53pm
Would you have the washer ground down, or the top of the nut? 1310cc TWINK - T Conversion |
