Home > General Chat > Power steering?
Has anyone else considered fitting this or is it just me? Lol
I don't know all that much about how it works but im thinking it could be a good way to help with my torque steer issues?
The corsa column + ecu adaptor doesn't look all that difficult to install or expensive, but not sure if it would be much of an advantage or not? Or if the 'mini go-kart feel' would be lost or maybe improved?
Anyone got any thoughts on this?
Matt
Torque steer should be solvable with suspension setup TBH. The DON does not torque steer, mainly because the suspension is all rose jointed.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Those colunms are fooking heavy. You couldn't undo all your hard work by fitting one
On 30th Apr, 2010 Rod S said:
Gary's description is best
If you have torque steer, and your geometry is in spec, you need to revise your offset to bring the contact patch closer to the KPI contact.
It is that simple - if you don't believe me fit a set of boggo metro wheels and try it.
oh, and yes - the 16v boys have a lot of stuff on the corsa columns on their site, but it is one SERIOUSLY HEAVY piece of equipment, plus you need to add bracing (weight) to make it happen.
I'd be interested to see how much weight a talented fella like you could get out of the corsa column though :)
i am thinking of fitting one ...... in the camper
I drove a scooby with an electirc P/S set up, it worked really well and felt fine. Can't help you out with issues fitting ect though.
Hmm some interesting points! I'd be interested to find out how much they weigh, they do look 'all there'. lol Thats the only real negative I could see with fitting one. Ive been scanning the 16v forum...lots of info but not found anything on weight yet?
The geometry is correctly set now and that has made a huge improved to the torque steer and general handling!
Sounds like I need to get hold of some inset wheels to see what effect they have. Although im guessing the geometry would need adjusting again just to try it?
I might see if I can get hold of a steering column and see what mods can be made to shed some of the weight anyway. :)
GaryOS
Member #: 2810
Dublin, Ireland
I just had a look on ebay to see how much they go for. I had no idea they were so cheap!
i have one at work that i could weigh and take LOTS of pictures of, including possible lightening areas...
Matty is your front suspension rose jointed?
Paul
James, that would be spot on if you could! If its stupidy heavy then I won't bother. Pics are always good. :)
Yeah they are damn cheap, so no great loss if it doesn't work apart from a little time.
Paul - no rose joints what so ever, is the ride ok on a road car?
Yes it is Matty, I got rid of a lot of what I thought was torque steer by fitting RJ bottom arms and tie bars then setting tracking parallel.
What was happening was as a wheel lost traction due to being stiffly sprung on bumpy roads, the car went in the direction the other wheel was pointing. As it was set toe out, the wheel with traction wasnt actually pointing forwards. It was all exagerrated by the Salisbury plate diff.
Paul
Scruffy
Member #: 328
Seaford Rise, South Australia
Paul
Which funnily enough is the diff fitted to most cars that have PAS conversions (probably unnecessarily judging by your comments!))
On 5th Sep, 2011 Vegard said:
nick1275
Member #: 1615
Ferndown, Dorset
mine torque steered like a bitch before i got the suspension geometry done, hardly does it now
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy
On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind.
I'm thinking of fitting one just because I'm lazy! The MGF column is worth a look as I think all the mpi switches etc will fit?
We considered this conversion at one point, but in the end fitted UJs in the column to get the steering wheel in a better position.
Having said that we have no issues with torque steer with 7x13s fitted.
Scruffy
Member #: 328
What diff do you have Wil?
And it has a Salisbury LSD.
So how much difference does tyre choice make to torque steer?
We now have the Minispares Evo plate diff, but no issues with an open diff uesd before we got the LSD either.
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
