Home > Help Needed / General Tech Chat > Megajolt - TPS Wiring
jonb_5
Member #: 3193
Torbay, Devon
I am at the stage of wiring in my megajolt, and have bought a ford TPS.
I need to know which way round the three wires go, VREF, TPS and 12 Ignition live, on to the TPS sensor.
Three terminals are labelled A,B,C
Which wire goes to which?
Jon
First, never connect 12volts to a sensor!
Use the 5volt output for the TPS from the MJ. (Vref)
TPS signal and ground will be the other two connections.
You'll need to look it up in a workshop manual or test the resistance of the sensor with a multimeter.
Edited by Bat on 25th Feb, 2009.
philc
Member #: 1346
bromsgrove
don't forget to check your software is setup for tps and not map
Normally the output is the middle one.
leroymornsey
Member #: 5265
telford
im at same stage and im also puzzled the megajolt one i have has built in edis4 my prob with the white wire is this for tacho as i am in the thinking blacks ground reds live and do u to have a red wire coming off coilpack lead is that the main live
garlic bread
will any old tps sensor of ebay do the job, or are there certain megajolt compatible sensors?
i remember being told to use a colvern type tps by someone but no idea how to tell them all apart?
Si P
Member #: 912
North Yorkshire
Test the TPS you have.
http://www.autosportlabs.org/viewtopic.php...light=teds#7840
Heres how I tested mine.
The Megajolt will calibrate the TPS once fitted.
Hope that helps
Si
Pretty much, I've tried a few different ones and had no problems with them.
cool, cheers rob
