| Home > Help Needed / General Tech Chat > rocker ratio? | |||||||
72 Posts Member #: 5062 Advanced Member Herts |
27th Feb, 2009 at 07:28:58pm
i've got some roller rockers from my old 1.1 engine, does anyone know how to find out what ratio they are? i've attached a pic if it helps.
27th Feb, 2009 at 07:38:38pm
look the same as my minisport 1.5s
27th Feb, 2009 at 10:36:53pm
measure from the centre of the pivot point to the centre of the roller and from the centre of the pivot point to the centre of the 'ball' that sits in the pushrod
Edited by slater on 27th Feb, 2009. |
27th Feb, 2009 at 10:53:32pm
1050 Posts Member #: 764 Post Whore Staffordshire |
27th Feb, 2009 at 10:55:57pm
ive heard that people have managed to do it.. but when i tried... i ended up replacing the gasket an hour after starting it
27th Feb, 2009 at 11:49:08pm
They look like Minisport 1.5's . At least they look identical to the one's I had.
In the 13's at last!.. Just |
28th Feb, 2009 at 12:21:19am
cheers guys, measured 2.2 one side and 3.3 the other. looks like its a 1.5.
28th Feb, 2009 at 06:36:26am
I,ve ALWAYS got away with it.I drain the water,ease the pressure on all the head bolts and then replace the rockers,re -torquing afterwards.Mind you, I have yet to try it on a turbocharged engine !. |
28th Feb, 2009 at 05:34:30pm
28th Feb, 2009 at 07:45:06pm
it is technicaly possible, but its going to be incredibly difficult to remove all the old gasket from the head and block.
28th Feb, 2009 at 07:59:48pm
1st Mar, 2009 at 09:19:01am
On 28th Feb, 2009 Barrythebodger said:
It would only take a couple of hours to take the head off properly, probably quicker than it would take to try and do it the other way. Or an entire weekend: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=142775 Isambard Kingdom Brunel said:
1st Mar, 2009 at 10:34:38am
as others have said, i have changed the rockers and not the gasket but did drain the water and slacken all the head nut slightly, worked fine.
1st Mar, 2009 at 11:31:36am
Turbo shed, you sound like my kind of guy! |
1st Mar, 2009 at 03:20:36pm
On 1st Mar, 2009 Turbo Shed said:
as others have said, i have changed the rockers and not the gasket but did drain the water and slacken all the head nut slightly, worked fine. also when changing the gasket i undo the manifolds from the head and leave them in place, then remove the head studs and pull the head forward and off. when refitting i have 2 very short studs i screw in place, slip the gasket over, slide the head back, put all but 2 studs back and then remove the short studs with a screw driver (i cut slots in the short studs) and pull them out with a magnet on a stick. That should be in the "Tips" post that TD started a couple of weeks ago.. Good one.. Edited by Turbo Tel on 1st Mar, 2009. website:- http://www.terryhunt.co.uk
