| Home > Technical Chat > Is your carb capable of boost? | |||||||
388 Posts Member #: 442 Senior Member Manchester |
5th Mar, 2009 at 07:50:27pm
Hi everyone. Ok first of all i dont post much on here but i am on the site fairly often. If what im about to say / show has already been done then fair doo's.
5th Mar, 2009 at 08:07:26pm
i did the same on my old engine, using 2 x 3mm sheets of ally i had kicking around a G-clamp and a pump too.. im yet to test this one, its a good method imo Yes i moved to the darkside |
![]() 338 Posts Member #: 1911 Senior Member Swindon |
5th Mar, 2009 at 08:31:25pm
hmm liking the idea, will do this with mine now, where is it likey to blow from? is it the seals on the butterfly spindle? |
5th Mar, 2009 at 08:32:48pm
It isn't that much different to the procedure that Austin Rover suggested. They just put it on a compressed air supply instead of a hand pump, and stuck it in a bucket of water. |
5th Mar, 2009 at 10:04:50pm
Yer mine was leaking from the spindle seals. I dont think ive got them in the right way tbh.
5th Mar, 2009 at 10:32:40pm
Well the seal only has 1 leading flat edge which to much rebuild book goes towards the face of the carb and I used a socket to just push it firm against the face either side of the spindle and then turned the butterfly by hand which evened everything up and left it like that. whether or not it gave a good seal is beyond me but will check now. |
6th Mar, 2009 at 10:10:31am
Once thats done though ill get hold of a boost gauge and make sure it dont leak
