Home > Help Needed / General Tech Chat > Which one is better
quinton
Member #: 1911
Is the first inlet manifold better than the second one as it has the water intakes to cool it down or would it only heat up the manifold if the IC is keeping things cool?
http://cgi.ebay.co.uk/MG-METRO-TURBO-HIF44...A1%7C240%3A1318
http://cgi.ebay.co.uk/MG-METRO-TURBO-ALLOY...A1%7C240%3A1318
If your using a totally standard install then plumbing up the manifold will most likely cool the inlet charge. But on an install with an efficient intercooler fitted, plumbing up the manifold would only heat the charge again.
quinton
Member #: 1911
What I thought, right cheers Phil for the answer now I know which one I will go for.
A non heated one will be useless in the winter....
quinton
Member #: 1911
sorry what winter!! mini and such a season don't correspond lol. She'll never seen a winter again in her life.
No need to worry about that then! :)
madcatminis
Member #: 5327
Dudley, West mids
I'd read somewhere (think it was calver) to never plumb in the inlet if power is what your after. I never plumb mine in. *Nerd*
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
prob viz said this too, i chopped off mine to make space, and the weather has been rubbish since!! i now find it hard to run on a cold day. carb icing bla bla,
up in the wicklow hills its cold every day!! doh, i still have snow!
I do agree all in all. just not sure its "an every day" car thing if you are not a bit of a fanatic (if so we all in right place eh1) could make it hard to live with on a frosty morning. eeemmmmmm cold starting in my girlfriends estate at 730 am in a frosty morning = frosty neighbours!!
Probably anyone with one physics class would say the same.
