| Home > Help Needed / General Tech Chat > running a little on the hot side | |||||||
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
8th Mar, 2009 at 12:58:22pm
after getting my turbo up and running last sunday, it seems to be overheating slightly under normal driving conditions (just over normal). obviously i can see this being an issue for track usage.
Edited by Monkeh on 8th Mar, 2009. |
8th Mar, 2009 at 01:14:09pm
If the fan is not right on the rad it will be doing next to nothing..
8th Mar, 2009 at 02:01:38pm
Fit the mechanical fan and your problam will go away On 17th Feb, 2009 Rob H said:
8th Mar, 2009 at 05:49:14pm
As above, also drill 2 holes in your thermostat 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
8th Mar, 2009 at 05:51:45pm
Have you checked the thermostat is not staying closed too long? On 7th Oct, 2010 5haneJ said:
