Home > Help Needed / General Tech Chat > Tail light wiring?
clubby_turbo
Member #: 403
sydney Australia
G'day, just wondering if anyone knows how the tail lights are wired up on a 78 clubman, i'v lookd through all the diagrams i have but none seem to make much sence, if anyone could just give me a description of what colours go where it would be greatly appreciated!
Cheers. Chris
998 turbo
They are all matched.
There are 4 wires:
Red
Green
Green with purple stripe
Green with pink stripe
They are matched light to loom (i.e red to red, green to green). I think the stripes are correct, but it should give you an idea.
Let me know if you want a pic or something (I have a 78 clubby)
clubby_turbo
Member #: 403
sydney Australia
Thanks for the reply, the problem is that i am making a new front wiring harness and retaining the rear and im not quite sure wich conectors go to wich spades on the back of the lights, a picture would be fantastic, appreciate you going to the trouble, its a simple problem but a fustrating one!
Cheers. Chris
998 turbo
I'm not really going to be at home until Saturday night, I'll get you a pick then.
clubby_turbo
Member #: 403
sydney Australia
thanks a lot for that, i even drove out to my "not so local" mini spares to find that the only clubman in the shop had broken boot lock that wouldnt open, when ever you get a chance will be fine.
cheers. Chris
998 turbo
Green White Rh indicator
Green Red LH indicator
Green Black Fuel sender
Green purple Brake lights
Red something tail lights
That should get the job done *wink*
clubby_turbo
Member #: 403
sydney Australia
Perfect, now with any luck i can finaly get my petty tank in!
Thanks for the replys.
Chris
998 turbo
