Home > Help Needed / General Tech Chat > which way does this mount??
MarkGTT
Member #: 1194
Shropshire.
pic 1
or pic 2 ?
the writing is the right way up in pic 1 but the haynes shows it as per pic 2
cheers.
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
As the second pic Mark, just had a look at mine and the unions that are closer together go on the top.
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Yeah second pic!
Build Thread Click Here
MarkGTT
Member #: 1194
Shropshire.
good job! as thats the way its gone in!
cheers chaps. :)
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Is it a new regulating valve or just really clean ?
"Try to take over the world!"
MarkGTT
Member #: 1194
Shropshire.
its new, an expense i didnt want tbh..
richminiturbo.
Member #: 719
They suck!!
If mine ever packs up im gonna run without methinks.
Personally I would have spent the dosh on an adjustable bias valve for the rear brakes and junked that compensator. Too late now though.
Mine is mounted in the bin. Where it belongs!
MarkGTT
Member #: 1194
Shropshire.
unfortunately my lack of knowledge told me this was the only way to sort my diagonal system out
e.g change to a front rear split with the expensive pressure valve thing.. *frown*
Vegard - i remember you saying it belonged in the bin when i asked if i needed one.. but assumed you were talking about the second hand one on offer..
oh well - will have to run with it now and see how i get on *oh well*
are these the ones that can be made adjustabubble?
Ben H
Member #: 184
Melton Mowbray, Pie Country
How are you using that to make a diagonal system?
http://www.twin-turbo.co.uk
miniminor63
Member #: 672
The oversills police
Oslo, Norway
No James, that are the ones that fit under the bootfloor
Edited by miniminor63 on 16th Mar, 2009.
MarkGTT
Member #: 1194
Shropshire.
im not, changed the set up to a front rear split.
miniminor63 - you mount it on the bulk head, not the boot floor.
That makes more sense. There seemes to be some confusion here.
There are three types of limiter valve.
1) Fits on the bulkhead and cannot be modified to make it adjustable
2) Fits on the bulkhead and can be modified to be adjustable
3) fits on the rear subframe (used in early single line systems) and can be modified to be adjustable.
Just don't ask me the differance between to two types that fit on the bulkhead.
advantage998
Member #: 1840
Kings Lynn, Norfolk
I'm pretty sure this type can be adjusted, as the adjustment gubbins is whats hidden under the crimped on cap on the left hand side.
That valve is also a safety valve so if you loose all pressure on either the front or the rear, it closes off that circuit preventing you from pumping out all the brake fluid.
whoopsie, shot twice
Edited by Sprocket on 16th Mar, 2009.
Si P
Member #: 912
North Yorkshire
that thing on the bulkhead (called a P.D.W.A. - pressure differential warning activator) is there purely to maintain line pressure in one half of the system (be it front/rear or diagonal split) in case of failure in the other. It DOES NOT regulate the line pressure when braking with the system working normally as many believe. Some of the regulation is done in the master cylinder, the rest with the wheel cylinders. Calver's words not mine.
No, i think you will find that it does regulate the rear brak pressure *wink*
MarkGTT
Member #: 1194
Shropshire.
thats how i understood it too.
heres pics of how mines mounted:
i wish i never asked....hahah
pot_dan
Member #: 326
bradford, west yorks
going off topic but mark has got his answer...
mine broke when my mot tester pressed the brake too hard trying to get it to pass. lol we had to bypass it with brake line to get home and was advised not to brake too hard... or half way round a corner even a little bit. lol unless in a wet car park. haha. wich i never did.... *wink*
minivan rick
Member #: 5645
middlesex ( near heathrow )
if i was to run a fig 8 front brake lines as era, to use a type 4 master would it be ok to run a split in from the rear of the master down to the rear , and then fit balis adjuster in for rear ..
or should i use the regulating valve and put the split for the front in after the master and the rear line after the regulating valve ?
Don't go slow !!! Go Turbo :))))))
