| Home > Beginners Tech > metro turbo brakes | |||||||
50 Posts Member #: 5265 Advanced Member telford |
17th Mar, 2009 at 05:59:31pm
hi there just wondered if anyone who runs metro 4 pot caliper set up has had any probs with it as i read a old mini world about it and it said because the metros suspention geo was different to a mini on a mini thay have a tendency to pull you all over the road.
garlic bread |
17th Mar, 2009 at 06:01:56pm
thats not the brakes, its the metro hubs that a similar, but slightly different and thus change the geometry, the brakes are fine
55 Posts Member #: 6376 Advanced Member oxon |
2nd Jul, 2009 at 08:10:02pm
i think that i remember reading that if you just put them on a standard mini setup they will run at a positive camber and that is where some of the odd handling comes from.
2nd Jul, 2009 at 08:12:25pm
if you put metro hubs on use the metro steering arm with them too. On 28th Aug, 2011 Kean said:
3rd Jul, 2009 at 12:24:46pm
Only the early metro hubs are a direct fit to a mini. unless you someone produced ball joints for metro hubs with mini tapers. Own the day
3rd Jul, 2009 at 12:26:14pm
I believe you can put early ball joints into the later hubs.
On 3rd Jul, 2009 Mr Joshua said:
Only the early metro hubs are a direct fit to a mini. unless you someone produced ball joints for metro hubs with mini tapers. If something is worth doing, it's worth doing half of. |
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
3rd Jul, 2009 at 01:07:45pm
The ball joints...
Pedro Silva
6th Jul, 2009 at 09:37:40am
Hi
