Home > General Chat > o/t tacho on a diesel
Hi guys,
Id like to fit a tacho to my transit, apparently there is a wire coming out of the alt that gives a pulse similar to the coil on a petrol?
is it simply a case of finding which one and fitting any old rev counter?
or is there more to it than meets the eye?
Joe
The W terminal gives out an AC wave which is what Ford use for the rev counter trigger. As to what rev counter will work with it I've no idea :(
i think they need to be special tachos (i.e diesel specific) from what ive gathered off the web so far...
hmmm
Andrew 998 mini
Member #: 5639
Weert Holland
You'd be best using the "W"terminal, and getting an external tacho of ebay or from somthing like autostyle etc or perhaps the later model transit cockpit will plug strght in.
with the after markt ons there is a wire for ilumination an negative and the "W" teminal trigger wire that's all.
Cheers, Andrew
Little car Little power........... For now That is!!!!!
1983 mini down paid, must collect soon and get welding!
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
