Home > For Sale > Gaz Coilovers (Rear)
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Howdy guys,
Bought these a while ago, have had them fitted on my car, but the car has moved about 2 metres in the past 2 years so they have never had any actual use. Have a few scratches and are abit dusty, but other than that brand new.
Bought them from Huddersfield as "Rear GAZ coil over shock absorber low offset kit
This kit comprises of 2 Gaz coil overs shock absorbers with a low offset and progressive rated springs to match."
They are £165 + pp new so im looking for £100 + pp.
They measure 14" from the two mounting points (radius arm stud to hole in wheel arch).
Ben.
Edited by Ben. on 19th Mar, 2009.
Build Thread Click Here
Give me first dibs on these. I guess Petterb will want them.
Are they lowered?
Edited by Vegard on 19th Mar, 2009.
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Ok mate,
Huddersfield sell two types, standard and lowered, these are the lowered ones.
Thats what they looked like, ive tubbed the sh!t out of mine though as you can see and the cars empty so they would be about an inch lower I guess. I think they would be as low as you could go without tubbing.
slater
Member #: 1291
Suffolk / Birmingham
Id be interested if 'big V' doesnt have them.
Could you do me a favor and measure closed lengths of them? (or just the length of the 'rod' will do) so i can take that away from the 14" and work it out myself
Edited by slater on 19th Mar, 2009.
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Well open they are 14" between the two mounting points (radius arm stud to hole in wheel arch).
Theres about 2 1/2" of travel left in the shock. So closed would be 11 1/2" plus however much the bump stop crushes.
petterb
Member #: 75
As V. said, I'll take them.I'll send you a pm
http://www.ktv.no/~pjb-ktv/
