| Home > Help Needed / General Tech Chat > Janspeed Manifold | |||||||
19 Posts Member #: 3103 Member |
1st Apr, 2009 at 10:26:42am
Hey, I was just wondering if anyone knew where i could get a decent view of an exhaust manifold from a Janspeed engine or some kind of drawing/measurements? As im looking at making one up. If anyone has made one similar or there abouts id like to get some advice from you
1st Apr, 2009 at 10:30:35am
Is this for a mini or a metro install? The Janspeed manifold won't fit on a mini.
1st Apr, 2009 at 10:39:33am
1st Apr, 2009 at 10:42:37am
This thread shows a few options (not necessarily Janspeed)...
In the 13's at last!.. Just |
1st Apr, 2009 at 10:42:53am
Mirage manifold enables you to fit a t2 without modding the bulkhead. If something is worth doing, it's worth doing half of. |
1st Apr, 2009 at 10:43:46am
If you just don't fancy cutting the bulkhead, the simplest option is to use a Mirage manifold.
1st Apr, 2009 at 10:46:49am
This is the one I was originall searching for. Lots of good pics here...
1st Apr, 2009 at 10:47:43am
Yeh thats what im looking for thanks theone...... Yeh i looked at the Mirage manifold and that is an option to i was just wanting to explore as many options as i could. Thanks for suggestion tho |
1st Apr, 2009 at 10:54:49am
If it's options that you want: My thoughs on mounting above the flywheel are that the simplest solution is to use the metro manifold with a pipe running from that to the new turbo position. Use a flexy bit to account for expansion.
1st Apr, 2009 at 05:12:14pm
Here's the Janspeed manifold but as Wil said, it won't fit straight into a Mini as it was designed for the Metro. |
