| Home > Help Needed / General Tech Chat > Dizzy less | |||||||
32 Posts Member #: 391 Member Darlington, N.East, UK |
22nd Oct, 2004 at 06:04:04pm
Hi |
![]() 1128 Posts Member #: 142 Post Whore Winchester |
22nd Oct, 2004 at 06:15:17pm
go to http://www.megasquirt.info and look up mega squirt 'n' edis, i've just ordered my kit, ben h on this forum has it in his car, the other option is a kit like turbo dave has, its more expensive than the mega squirt
22nd Oct, 2004 at 06:16:41pm
i'll just add that although the kit dave is running is expensive it is actually a pretty serious bit of kit, if you can afford it then go for it |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
22nd Oct, 2004 at 06:49:40pm
Is megasquirt the EFI?
Bugger off, I'm getting there. |
22nd Oct, 2004 at 07:25:34pm
the mega squirt ecu is for injection but if you mod it slightly you can use it to run ignition using ford components, its like the mega jolt i think but its been around longer and has less bugs in it
969 Posts Member #: 47 Post Whore Not very sunny swanage |
22nd Oct, 2004 at 07:58:22pm
dan how much is the megasquirt and edis, and where are you getting it from? the only person ive found in this country that deals with them is bill shervington. also, isnt megasquirt and edis a bit of an overkill when your not going to inject? wouldnt you be better off using a megajolt kit, or are there a lot of unresolved bugs that mean its not a good idea?
And on the 7th day........... God created turbochargers! |
22nd Oct, 2004 at 08:04:17pm
i have ordered my kit from the states, you just need to go to the bank and get a money order and send it over, i have only ordered the ecu, i'll get the resistors etc from maplins or somthing, i am going for megasquirt n edis simply because i know ben h has it running in his car and its proven to work but i'm sure there's other reasons why you should choose it over the mega jolt, ben h might know more though?
22nd Oct, 2004 at 09:51:37pm
I have little experiance of the megajolt, but as has already been mentioned the megasquirt&edis has ben around ages and has most of the bugs fixed. It works exactly the same as the mega jolt.
http://www.twin-turbo.co.uk
23rd Oct, 2004 at 09:25:05pm
thank you guys |
23rd Oct, 2004 at 11:17:48pm
Advantages...
24th Oct, 2004 at 11:34:11am
No offence taken. Megasquirt has been around for long enough now for it not to be seen as cheep, but rather good value. The software used to tune it is much like any others I have seen and any tuner that has used one before will have no problem using it. In fact i would say it is extreamly easy to use because it has been designed and modified after lots of people have given feedback on how it operates.
24th Oct, 2004 at 10:48:55pm
I'm obviously going off what i found out about megasquirt a few years ago then... Can you program it via a laptop using a 256 cell display (or somet similar)?
25th Oct, 2004 at 11:46:55am
Yep it is all through a laptop with a serial link and looks like many other systems, working in a windows environment. Infact we have recently had the tuning working through a palm pilot which can double up as a dashboard.
25th Oct, 2004 at 11:54:17am
hmmm - I need to look more into this!
25th Oct, 2004 at 12:18:31pm
megasquirt http://www.megasquirt.info/
